Coolant leak by timing belt
Old Feb 18, 2008 | 08:06 AM
Lude-Lee's Avatar
Default Coolant leak by timing belt
Its like there a leak some where by the timing belt but cant tell where. When under the car and there small coolant drop on bottom of oil pan.
-the raditor is full
-the coolant reservoir tank goes empty every other day.
-not overheating
-could be water pump
-check lines but not positive
-4th gen prelude
-JDM H22a
Old Feb 18, 2008 | 09:05 AM
johnny five's Avatar
Default Re: Coolant leak by timing belt (Lude-Lee)
water pump most likely
when was the last time you changed your water pump?
Old Feb 18, 2008 | 11:01 AM
royalfelix's Avatar
yah i had the same problem like 2 years ago and its the water pump. if you look closely you can see its coming out of a small hole on the block. 95% sure its the water pump if its com,ing from the timing belt area ( but on the back side)
Old Feb 18, 2008 | 12:27 PM
bb4socal's Avatar
Default Re: (royalfelix)
i say water pump bleeder hole or the pump itself. just change it...and while your at it, do timing belt and tensioner. your not gonna wanna do it later.
Old Feb 18, 2008 | 01:24 PM
JasonST's Avatar
Default Re: (bb4socal)
Water pump! When they're on their last breath they start peeing out the weep hole.
Old Feb 18, 2008 | 03:48 PM
mattsnooz's Avatar
Default Re: (JasonST)
Its always Coolant that comes out of the weep hole right? (green coolant, or pink/other colours now) Not just clear water by some magical means? I see water periodically under that general area, but havn't figured if it could be only dripping from a wet underside or whatever.
Old Feb 18, 2008 | 04:19 PM
Lude-Lee's Avatar
I know things dont fix it self but it stop leaking. It use to .....DRIP..DRIP..Pisssss.lol
I when to this import honda service shop that said 350 with labor.....I'm like F U, Them crack head prices! Im not know sucker.
Most likely go to advance and but the parts and take it to another shop.
BUT
-When it was dripping it was clear with a dash of green. whats up with that?
Old Feb 18, 2008 | 06:11 PM
bluedlude's Avatar
Default Re: (Lude-Lee)
unfortunately $350 to change the water pump is not an unreasonable price when taking it to a shop.
Old Feb 18, 2008 | 07:50 PM
Lude-Lee's Avatar
Default Re: (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">unfortunately $350 to change the water pump is not an unreasonable price when taking it to a shop.</TD></TR></TABLE>
You know im Thinking it would be a good D.I.Y But Im not positive if it would work out.
wedtm
Mar 26, 2008 07:59 PM
b18c4door
Jan 8, 2007 07:42 AM
rafiq7
Nov 30, 2004 09:16 AM
Seye
Mar 28, 2004 03:26 PM
Sephro
Mar 20, 2003 11:19 AM
