Mugen metal clutch/ressure plate set for ITR (Brand new)
This is a clutch designed for racing and sports use. This clutch set is a thin single-plate type that transmits the engine output to the drive train reliably without losses. The reinforced clutch cover, which allows precise clutch-work, has a reinforced diaphragm that compresses the pressure plate even under repeated clutch action. Reinforced bolts and springs are used in the plate unit to enable it to withstand severe use, and the fading material is metal. This gives an excellent clutch feel together with consistently high friction performance (fade recovery) over the entire temperature range. The clutch cover and metal disk are used as a set.
Asking $480 shipped or $450 pickup. Locate in So Cal
http://www.kingmotorsports.com/produ...nsmission.html
[Modified by typeRP, 4:52 PM 7/18/2002]
dopeyesw310
Jul 14, 2009 06:14 PM
b19coupe
Mar 3, 2004 11:34 AM
