Aquafina FS thread.
Old Feb 18, 2008 | 01:32 AM
Aquafina's Avatar
Default Aquafina FS thread.
Prices do NOT include shipping. No lowballs. Pay with paypal (add 3%) or MO (USPS only). See my biography for vouches.
D17A1 head, no valve cover, what you see attached to it in the pic is what you get. $75
D17A1 water pump $5
D17A1 alternator bracket/mount $10
D17A1 breather chamber cover $2
D17A1 knock sensor $5
D17A1 oil pressure sensor $5
87 CRX Si CVCC
OEM Honda exhaust gaskets never opened (2) 18110-PEO-010 $3/each
Weber DGAV 32/36 on a 87 CRX Si CVCC ported IM. Carb comes with everything in pic except the exhaust gaskets. $200
OEM Honda hub never opened 42200-SD2-008 (86-89 Integra rear hub) $100
OEM Honda hub never opened 42200-SF4-008 (84 Civic 1300, 1500 Sedan/hatchback, CRX 1300, CRX 1500 rear hub) $80
B18C1 OBD2 distributor $120
H22A4 VTEC solenoid $20
D16Y8 busted as **** VTEC solenoid $1
F22B2 intake manifold WYSIWYG $50
D16Y7 intake manifold WYSIWYG $30
90 CRX Si clock $4
90 CRX Si main relay (unknown if it works, deleted from race car build) $5
90 CRX Si atmospheric pressure sensor $5
90 CRX Si light and wiper stalks (deleted from race car build) $10
D16Y7 airbox, intake arm, resonator (not pictured) $10
F22B2 valve keepers $12
F22B2 valves -1 exhaust $15
F22B2 block. Includes block, girdle, oil pump, balance shafts, crank end plate, main bolts, oil pickup. $50
F22B2 rods/pistons $10
F22B2 crank $25
B18B rocker arms $15
B18B rocker arm mount nuts $16
B18B valves $16
B18B valve keepers $12
B18B valve springs $15
D15B7 lower timing cover $2, belt tensioner $3, oil pressure sensor $1, water pump $5, alternator bracket w/bolts $1, oil pick up $1
D15B7 crank pulley with key and bolt (not pictured) $20
D15B7 oil pan $15
D16A6 distributor, needs cap and rotor. $50
DOHC ZC halfshaft $50
D16Z6 oil pan $15
D16Z6 oil pickup $1, water pump $5, alternator bracket w/bolts $1
D15B6 rods/pistons $10
D15B6 oil pan $12
B18C5 valve springs, 98k on them. Worked fine when removed. $40
B18C5 cam gears $10
B18C5 valves minus 2 intake. 98k on them. $25
96 D16Y7 5spd ECU works fine, removed from my car after changing to OBD-I. $15
00 D16Y8 ECU (unsure if its 5spd or not as I don't know much about the OBD-II VTEC ECU's) $15
87 CRX Si transmission. Mileage unknown. Came out of a track only car. Quaife LSD. Comes with aftermarket axles, brand unknown. $1,000 shipped in the continental US.
Kirkey Drag Racing Layback seat 41 series with cover. I think its a 16 or 17". Will measure it. Never used, only mounted. $200
Modified by Aquafina at 5:29 PM 3/13/2008
Old Feb 18, 2008 | 09:22 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: Aquafina FS thread. (Aquafina)
Old Mar 13, 2008 | 01:30 PM
Aquafina's Avatar
Added Kirkey seat and CRX Si Quaife trans.
myed9crx
Southeast (Sales)
Jun 24, 2011 03:55 PM
myed9crx
Jun 24, 2011 03:53 PM
Aquafina
Southeast (Sales)
Mar 13, 2008 01:28 PM
crxvtecturbo
Jan 12, 2005 10:07 PM
