HELP stripped bolt
Old Feb 18, 2008 | 12:13 AM
Honda_ThuGZ's Avatar
Default HELP stripped bolt
(90 civic manual)
i found out the fill bolt on my tranny is completly stripped.Whats my best option to remove it; its a very tight spot need some ideas asap.(vice scripts didnt work i think it might have lock-tight)
Modified by Honda_ThuGZ at 1:38 AM 2/18/2008
Old Feb 18, 2008 | 12:29 AM
jdmcivicturbo's Avatar
Default Re: HELP stripped bolt (Honda_ThuGZ)
i believe its a 17mmm hummmmm know any body with a set of metwrench tools... or better yet i take it that you're pulling the tranny out... cut the bolt... when you have the tranny off, there should be about an inch or so still sticking out, and you should be able to just turn it with your fingers.. but this will stratch your tranny though.. hahah last option of course
Old Feb 18, 2008 | 12:33 AM
Default Re: HELP stripped bolt (jdmcivicturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicturbo &raquo;</TD></TR><TR><TD CLASS="quote">i believe its a 17mmm hummmmm know any body with a set of metwrench tools... or better yet i take it that you're pulling the tranny out... cut the bolt... when you have the tranny off, there should be about an inch or so still sticking out, and you should be able to just turn it with your fingers.. but this will stratch your tranny though.. hahah last option of course</TD></TR></TABLE>
yea its a 17mm.... man im thinking about just getting a b-series stupid bolt!
Old Feb 18, 2008 | 12:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_ThuGZ &raquo;</TD></TR><TR><TD CLASS="quote">
yea its a 17mm.... man im thinking about just getting a b-series stupid bolt!</TD></TR></TABLE>
if they are the same that is.. then you should be fine other wise go to a pick and pull and pocket one.. i've used b series bolts on my setup before and with so much torque when you're putting it back in, if longer it might just crack your block.... seen it happen before... and then sometimes when you dont get a long enough bolt it just pulls the treads out.. so be very careful unless you want to run one less tranny bolt.. what kindaa car anyways and 916 huh ... sac town.. ??
Old Feb 18, 2008 | 04:37 PM
my bad i ment ima get b-series cuz i cant get the bolt out
its a stock civic yea im from sac
Old Feb 18, 2008 | 05:46 PM
dj-t's Avatar
try using a wrench box end a little size smaller and hammer it in.
or a cold chisel and tap it from one side and see if it turns.
Old Feb 18, 2008 | 05:52 PM
Kevin B's Avatar
Default Re: HELP stripped bolt (dj-t)
Try a pipe wrench, the one that plumbers use.
Old Feb 18, 2008 | 06:25 PM
Default Re: HELP stripped bolt (Kevin B)
this bolt is so F.ed up that its oval.... i was able to get a grip off it n i noticed when i tried crankin it the whole tranny was moving...... this tranny flush is getting pretty expensive
Old Feb 18, 2008 | 07:40 PM
zrickety's Avatar
find whatever will grip it tight and set that aside...heat up the area around the bolt with a torch (if you can do so without burning anything important). the hotter the better, then grab it with your tool and it should unscrew pretty easy. this is the only way i know that can remove impossible bolts
Old Feb 18, 2008 | 10:09 PM
Default Re: HELP stripped bolt (zrickety)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">find whatever will grip it tight and set that aside...heat up the area around the bolt with a torch (if you can do so without burning anything important). the hotter the better, then grab it with your tool and it should unscrew pretty easy. this is the only way i know that can remove impossible bolts</TD></TR></TABLE>
well its the tranny and its oily so idk if i can really put a torch to it i aint trying to kill myself lol
Old Feb 19, 2008 | 11:59 AM
zrickety's Avatar
Lol...i know. but as long as there is no open hole to the oil, you should be safe. i did this once on a beretta fuel filter...yea torch on the fuel line...it was rusted solid and i was scared, but it worked and nothing bad happened
Old Feb 19, 2008 | 06:26 PM
i gotta try that this bolt is killing me
SL0Wcrx
Aug 1, 2019 03:58 PM
jimmyrab
May 20, 2008 07:03 AM
S1NFUL RL1 619
Mar 18, 2008 04:36 PM
VTC_CiViC
Sep 23, 2002 08:44 AM
