HELP ME MY ACCORD IS OVER HEATING!!!!
i have a 99' honda accord v6, my accord over heats when i go more then 30 miles i put in a oem thermostat from honda dealer. And still over heats only when a go far. i check my radiator coolant is fine fans turn on. water pump is fine. what else can it be???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob’S_dA »</TD></TR><TR><TD CLASS="quote">i have a 99' honda accord v6, my accord over heats when i go more then 30 miles i put in a oem thermostat from honda dealer. And still over heats only when a go far. i check my radiator coolant is fine fans turn on. water pump is fine. what else can it be???</TD></TR></TABLE>
If you installed the thermostat incorrectly (backwards would be the only way this could be done), the engine would overheat in 3 minutes not 30 (well maybe 5 minutes or so, give or take).
Your problem could be quite a number of different things, from debris on the front of the radiator (easy to fix) to a blown head gasket (not easy). Have it checked by a cooling system specialist, or provide more detailed information.
kevinp1
Jun 30, 2012 06:47 PM
AzHondaPhx
May 10, 2012 05:30 PM
silver99accord
May 8, 2012 05:42 PM
newludecincin
May 19, 2008 07:53 AM
