Z6 Head vs Y8 Head
Old Feb 17, 2008 | 07:48 PM
SilverBulletY8's Avatar
Default Z6 Head vs Y8 Head
I have a built Y8, but I have alot of valve clatter at 2500RPM +, on top of several broken bolt holes both in the cam cradle and in the head itself. My question is what do you guys think of a Z6 head vs another Y8 head... I have heard it both ways, but I was just looking for thoughts...
Old Feb 17, 2008 | 08:05 PM
ddd4114's Avatar
Default Re: Z6 Head vs Y8 Head (SilverBulletY8)
What are your goals? They both have pros and cons.
Old Feb 17, 2008 | 09:35 PM
well as of right now, she is all motor, but eventually, I am going to boost it... Been having head trouble ever since putting the motor back together. The overall goal... somewhere around 300hp... hadn't really thought about numbers... just building a solid street car.
Old Feb 17, 2008 | 09:55 PM
quicksilver1689's Avatar
i ♥ snails
nothing wrong with either, y8 seems to burn a little faster requiring slightly less timing under boost, im a big fan of the z6 motor, pretty stout for a little pos, plus u get a better oiling system
Old Feb 17, 2008 | 10:00 PM
ddd4114's Avatar
Since you'd like a 300whp car, I assume (or at least hope) that you're going to be turbocharging the engine. The z6 is best suited for this application.
Old Feb 18, 2008 | 10:38 AM
Default Re: Z6 Head vs Y8 Head (ddd4114)
definately going boost, I just want to be sure that the rest of the motor is stout first...
Old Feb 18, 2008 | 10:48 AM
nub's Avatar
nub
stock y8 compression -- 9.61:1 y8 block w/ z6 head -- 9.21:1 if you gunna boost it 9.2:1 is a little more friendly but its a small diff.
Old Feb 18, 2008 | 02:22 PM
Default Re: Z6 Head vs Y8 Head (nub)
when the block was built, we upped the compressionby decking the block and head as well as using flat top CP pistons (.30 over)... The compression right now is just above 10:1
Civic98KH
May 16, 2007 09:16 AM
aja345
18
Apr 24, 2007 02:19 PM
keepinitsimple
Feb 17, 2005 11:32 AM
Harry_Randal
10
May 18, 2004 08:43 PM
crooked muffler
Mar 23, 2003 11:20 AM
