Just a few ?'s about my build...
GSR block, .25 bore and hone, PCT pistons (OS), ARP rod bolts(rods shotpeened) and ARP headstuds, but am looking to make my compression safe for DD'ing, where would I find/purchase a 3 Layer OEM B series headgasket in order to finish this build?
I'm also going with a unported B16a head with skunk2 stage2 cams, valvesprings, and retainers, Skunk2 IM, OEM valve guides, and valve seals, (would Supertech or Skunk2 valves need to be used or could I remain stock?) but have seen a few builds which make more power with the Pro1 cams? What would you guys suggest, go with the Pro1's or stay with the stage2's, again this is for a DD? Also going to finish this build off with a Hytech Replica, BC Spec II exhaust, and AEM v2, Walbro Fuel Pump, 310cc Injectors, as far as tuning, probably going to be tuned with eCtune...looking to make 220WHP, hope that's a reasonable goal with this setup on a unported head, just looking to see what you guys would suggest for me to get to that goal, appreciate all the input
yeah you could use an oem headgasket. as long as the compression is 12:1 or under you will be fine with pump gas and daily driving. i am using skunk2 stg 3 tuner series cams on daily driver. so stg2 would be fine. and i would never replace cams without doing valvesprings. you could either use skunk2 or supertech valvetrain. i use supertech and it is around 550 for everything. valve, springs, and retainers.
ALLOUT CL55
30
Jun 27, 2010 09:32 AM
2001B18C1GS-R
10
Jan 1, 2007 09:28 AM
