Suspension & Brakes Theory, alignment, spring rates....
Problem with brake pad onto Caliper
Old Feb 17, 2008 | 12:17 PM
EGfosho's Avatar
OG Tech
Default Problem with brake pad onto Caliper
I recently bought a JDM integra gsr front brakes. I just recently bought PBR XBG integra brake pads, but the pads will not fit on the caliper and the pads look totally different from the stock ones I took off. I was wondering if the PBR brake pads are wrong or my brakes are from a different car? I took some pictures.
It says 160L14VN on both calipers. At the top near the brake like it says 53G
Thanks for the help.
Old Feb 17, 2008 | 01:18 PM
Targa250R's Avatar
be professional
Default Re: Problem with brake pad onto Caliper (EGfosho)
The brake pads are correct for a '94-01 Integra front application (FMSI D617), but those calipers are wrong.
'94-01 Integra front calipers are marked 17CL14VN (as are '90-93 Integra calipers, but those use a different bracket and pad).
16CL14VN calipers are from a '93-95 Civic EX 2dr non-ABS, '94-97 del Sol VTEC, '02-06 RSX base, and '07-08 Fit. They take an FMSI D621 pad.
Old Feb 17, 2008 | 02:41 PM
EGfosho's Avatar
OG Tech
Default Re: Problem with brake pad onto Caliper (Targa250R)
thanks for the info, I need to return these then. The rear says 7CLP13S. I hope at atleast the rear brakes are DC2.
Can I actually just get the 17CL14VN caliper and mounting bracket and swap it on the EG SIR knuckle?
Modified by EGfosho at 4:02 PM 2/17/2008
Old Feb 17, 2008 | 03:02 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGfosho &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info, I need to return these then. The rear says 7CLP13S. I hope at atleast the rear brakes are DC2.</TD></TR></TABLE>
They are. 7CLP13S rear calipers are almost universal for rear disc brakes on '88-00 Civic/CRX/del Sol and '90-01 Integra. Only Type-R trims came with different rear calipers.
Old Feb 17, 2008 | 03:04 PM
EGfosho's Avatar
OG Tech
Oh ok, cool. Do you know anything about my updated question?
Old Feb 17, 2008 | 03:23 PM
Targa250R's Avatar
be professional
As far as I'm aware, the JDM EG6 SiR used the 16CL14VN front caliper and D621 front pad. I'm not sure if this applied to both ABS and non-ABS EG6 models though.
The '94-01 Integra non-ITR used the 17CL14VN front caliper and D617 front pad.
Both cars shared the same 10.3" front rotor.
Old Feb 17, 2008 | 10:15 PM
EGfosho's Avatar
OG Tech
really. I heard that the SIR came with a different caliper. Maybe you are right. I got these brakes from a JDM shop that only carry JDM stuff. I measured the rotor and it is the same size has my friends GSR. I measure from center to center of the holes on the knuckle where the caliper mounting bracket goes and it is the same as mine. The guy at the JDM shop was telling that the EG6 is the same as DCs. But what i got is something different.
Old Oct 6, 2009 | 05:13 AM
R1020's Avatar
back from the dead...
THANK YOU, Targa250R, for this incredible tidbit of information. i have spent the past three days trying to locate a correct-fitting pad (hawk HPS to be specific) for my '93 non-ABS canadian-spec Si coupe (EX coupe in the US). there are two brake shops nearby who carry hawk pads that just can't seem to get me the right pad. i even called hawk themselves, who don't even know what pad i should use... sad.
based on your info, i'll be ordering the HB418F.646 and will finally be able to sleep at night.
thanks again!
peter
mattp27
Oct 13, 2013 09:48 PM
jakfrost84
Suspension & Brakes
Apr 21, 2009 09:47 PM
FuNkDrSpOt
Suspension & Brakes
Sep 19, 2008 08:08 AM
crexer
Oct 1, 2005 09:30 AM
IntEGNYC
Jun 24, 2005 04:43 AM
