Hondata Crank Sensor ??????'s
I need to know if I S300 on a 99 si without the crank fluctutation sensor. I got a B20/vtec now and my pump doesnt have the crank sensor mounting. Am I able to turn that sensor off and or does hondata even use this???Thanks
I'm pretty sure you will deff. need that sensor. I think thats how the rpm's are read and without that, i dont think it will even run. Don't hold me to it though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">I'm pretty sure you will deff. need that sensor. I think thats how the rpm's are read and without that, i dont think it will even run. Don't hold me to it though.</TD></TR></TABLE>
Thats done by the use of the crank angle, TDC and cylinder position sensor which are all in the dist.
No you dont need the crank fluc. with chipped ecus.
