Which Obd is this??
Old Feb 17, 2008 | 10:44 AM
matmcg's Avatar
Default Which Obd is this??
These are 2 distributors I need one converted to the black harness picture
Old Feb 17, 2008 | 10:52 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Which Obd is this?? (matmcg)
Top looks obd1, and the bottom looks older such as obd0.
Also, if there was an obd2, it would be one plug.
Old Feb 17, 2008 | 10:56 AM
matmcg's Avatar
so basically i need to convert obd0 to obd1 ...
I am wondering if this is as easy as cutting wires and reconnecting to matching colours
Old Feb 17, 2008 | 11:06 AM
northemt88's Avatar
Default Re: (matmcg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">so basically i need to convert obd0 to obd1 ...
I am wondering if this is as easy as cutting wires and reconnecting to matching colours</TD></TR></TABLE>
honestly i would sugest a jumper,
why the switch?
Old Feb 17, 2008 | 11:33 AM
matmcg's Avatar
I have to swtich them cuz the dizzy from my car is blown i picked this one up i guess its from a DA and i need to change the harness to fit my engine
Old Feb 17, 2008 | 11:42 AM
matmcg's Avatar
can i just cut wires and reconnect?
Old Feb 17, 2008 | 11:44 AM
northemt88's Avatar
if you run that one you'll need to swithout your ecu and your ingectors and dump your risistor box
Old Feb 17, 2008 | 11:50 AM
matmcg's Avatar
Default Re: (northemt88)
Why is that ?
My car should be Obd1 its a 95
this is from an older integra shouldnt the wires just swtich
Old Feb 17, 2008 | 12:10 PM
matmcg's Avatar
bump
Old Feb 17, 2008 | 12:39 PM
northemt88's Avatar
never mind thought it was going the other way,
i think it might work but i think you need to change a blue and a black
Old Feb 17, 2008 | 12:46 PM
jdm_bones's Avatar
The top one is OBD1, and the lower one OBD0...It's easyer to take the pig tails and swap them...I don't know if it possible with the OBD0. I know that it can be done with OBD2 to OBD1 or vasa versa.
dougshatch
Apr 20, 2007 10:47 AM
myEK=slow
11
Aug 21, 2006 08:20 PM
CR-V-tech
Nov 26, 2003 10:52 PM
turbotime.
20
May 25, 2003 11:52 PM
