Does a Triptronic auto tranny fit a "95 Accord?
Old Feb 17, 2008 | 09:22 AM
Dressed Accordingly's Avatar
Default Does a Triptronic auto tranny fit a "95 Accord?
My '95 accord is an automatic and i would like to keep it that way. I will be doing an H22 swap in the next couple weeks and would like to use the triptronic auto transmission out of an '01 prelude,buti know they are quite a bit larger. Will it fit directly into my accord or do these not swap in with the H22 as well?
Old Feb 17, 2008 | 09:44 AM
TheMuffinMan's Avatar
He knows where you live!
No
Old Feb 17, 2008 | 09:51 AM
So a manual conversion is the only way to do an H22 swap into it?????Sounds like i'll just be boosting my F-Series instead
Old Feb 17, 2008 | 09:56 AM
No, just get an OBDI motor/tranny and swap that.
Or get an OBDII that doesn't have tiptronic.
Old Feb 17, 2008 | 10:29 AM
So they made 97+preludes with an auto only tranny with out the triptronic....or i have to use pre 97 prelude or pre 98 accord right?
Old Feb 17, 2008 | 10:43 AM
Default Re: (Dressed Accordingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dressed Accordingly &raquo;</TD></TR><TR><TD CLASS="quote">So they made 97+preludes with an auto only tranny with out the triptronic....or i have to use pre 97 prelude or pre 98 accord right?</TD></TR></TABLE>
It would be a JDM Motor
You're already OBDI why are you wanting to go to OBDII ?
Just get an OBDI automatic motor
Old Feb 17, 2008 | 11:31 AM
i have found 3 JDM H22's and one usdm H22 for sale locally for around $1,000-$1,200. But they are three manual trans and one triptronic i have'nt came across any actual automatic motors yet.....Thanks for the help though dude.
Old Feb 17, 2008 | 11:32 AM
oh and would an F22 automatic trans bolt up to an H22 motor? i found one of those for $400
Old Feb 17, 2008 | 12:15 PM
Do research
Seriously
Look at any online motor place
Look at the Accord FAQ
Look at what other people have swapped
You're OBDI, they make OBDI h22's why you want a 97 + I have no idea
You can get an OBDI H22 w/ automatic trannys
Seriously there's some on ebay almost all the time
Old Feb 17, 2008 | 12:19 PM
i was just curious thanks for the info. I was just trying to find one local though i have no credit cards ect.
Old Feb 17, 2008 | 12:38 PM
In Missouri?
I don't really see that happening haha.
Get a checking/debit card and use it as a visa.
Old Feb 17, 2008 | 02:22 PM
I know it seems like 8 of every 10 hondas here are boosted B series swapped or K swapped
Old Feb 18, 2008 | 05:32 PM
Gen5Builder's Avatar
Default Re: Does a Triptronic auto tranny fit a "95 Accord? (Dressed Accordingly)
Dude can't this guy use his auto tranny from his Accord which is probably an F22B non v-tec on a 91-94 Lude H22 engine with no problem?
Old Feb 18, 2008 | 05:44 PM
Default Re: Does a Triptronic auto tranny fit a "95 Accord? (Gen5Builder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gen5Builder &raquo;</TD></TR><TR><TD CLASS="quote">Dude can't this guy use his auto tranny from his Accord which is probably an F22B non v-tec on a 91-94 Lude H22 engine with no problem?</TD></TR></TABLE>
1) Yes
2) It'll drop out of Vtec
3) Long lame gears
Old Feb 18, 2008 | 07:52 PM
SkimN's Avatar
you could use triptronic, but there are two problems, you're obd1 so you would have to convert it to obd2. Then you would have to spend hours upon hours wiring it, no one has done this so you're on your own.
It can be done, alot of the Stratus guys do it and it plugs up, but thats with the same chassis.
If you're not scared of wiring and diagrams go for it
Old Feb 20, 2008 | 07:38 AM
professorman's Avatar
Default Re: (SkimN)
Dont do it! Trust me! The Tiptronic Auto Tranny in the 97+ Preludes are TOTAL JUNK!! Do a little research. They have a design flaw, and when you put the power of a H22A on it, it dies at around 100k miles. I had a 98 Lude, and I felt like I was on borrowed time. I didn't want it to go out on me after reading all the horror stories. Then my shifting started getting worse at 135k miles. It was a shift solenoid. It fixed the problem, but I didn't want to be stuck with a dead Lude like countless other people with those Auto trannies.
BoneDizzle
Apr 14, 2010 04:49 AM
meandino
Feb 5, 2010 02:34 PM
KaiKasei
Nov 17, 2009 08:58 PM
GReddy SI
Nov 20, 2004 12:15 PM
G_Man604
Aug 3, 2003 10:00 AM
