Suspension & Brakes Theory, alignment, spring rates....
Lowering Spring Problem
Old Feb 16, 2008 | 09:48 PM
Dave_Dc2's Avatar
Default Lowering Spring Problem
Okay guys, i have a set of eibach sportline lowering springs on one of my integras..well the back is lowered pretty good but the front is really high, like stock height if not, higher even. I was wondering do they need time to weaken and settle down, or are they just designed for the front to be higher than the rear?
Old Feb 17, 2008 | 08:00 AM
CRX Lee's Avatar
Default Re: Lowering Spring Problem (Dave_Dc2)
Something is installed wrong. The first two things that pop to mind are that you might have the rear springs on the front and vice versa. Don't laugh, it happens more than you think and it results in a low butt and a high nose. Check the part numbers on the springs and then with the manufacturer's info to assure that they are not swapped end for end.
Second, if you have KONI shocks on the car, make sure that you don't have the removable front spring perches flipped upside down. The front perch should have the outer edge reach down like a bell and not up like a cup. The rear spring perches are meant to be up like a cup and is the only way that end can be done. This too is a surprisingly common mistakes.
Dollars to doughnuts, my bet is one of these two. Luckily both are pretty easy to identify and pretty easy to fix.
Old Feb 19, 2008 | 02:37 AM
tekturbo's Avatar
same ish happened to me except the nose was in the ground and the *** was higher than stock like a funny car. But we fixed it , the problem was the rear springs were on the front and vice versa and people swore that we had the wrong springs but thats all it was they were in the wrong place ,dont feel bad it happens .
JarvisW
Suspension & Brakes
Jul 24, 2009 12:33 PM
VTECAcuraGSR
36
Mar 27, 2006 03:43 PM
AssPenny
Jan 30, 2002 09:42 PM
owen_the_soyboy
Jun 29, 2001 12:43 PM
