I NEED HELP!! COOLANT IN BLOCK
Old Feb 16, 2008 | 08:34 PM
soodominican's Avatar
Default I NEED HELP!! COOLANT IN BLOCK
Ok so I was going to change the head gasket and i see liquid in my pistons, or the hole where the pistons go thru w.e u wanna call it... the car runs though... should i just dry it all up slap on the head gasket and put it back together? i don't know what to do, or what questions to even ask... help please thanks
Old Feb 16, 2008 | 08:37 PM
alscrx's Avatar
Default Re: I NEED HELP!! COOLANT IN BLOCK (soodominican)
Yes dry the cylinders....water gets in there when you remove the head, No big deal. Just make sure you soak it up.
Do not leave water in there, As water can not be compressed!
Old Feb 16, 2008 | 08:41 PM
Default Re: I NEED HELP!! COOLANT IN BLOCK (alscrx)
should i take a bunch of bounty and just dry as much as i can? or is there a better way? cause bounty sounds kind of ghetto
Old Feb 16, 2008 | 08:44 PM
alscrx's Avatar
Use an old white t-shirt because they should be lint free.....bounty will leave the white lint behind
Old Feb 16, 2008 | 08:47 PM
ok thanks, if anything ill just revisit this thread. by the way you know anyone with an si harness for a d-series? im tryna get rid of a z6 but its missin wiring harness and ecu and id like to complete it before i sell it
CRuby
33
Nov 20, 2014 11:07 AM
kkarl
Nov 18, 2012 08:35 PM
turbols99
Feb 5, 2007 07:28 PM
vermilion
Aug 9, 2006 04:03 PM
Mjh787
18
Jun 14, 2006 07:01 AM
