Suspension & Brakes Theory, alignment, spring rates....
¿¿Bump Stop??
Old Feb 16, 2008 | 07:57 PM
jayden1295's Avatar
Default ¿¿Bump Stop??
i was wondering if the bump stop can be loose or dose it have to be tight on the strut or it dosent really matter thanx
Old Feb 17, 2008 | 08:42 AM
Targa250R's Avatar
be professional
Default Re: ¿¿Bump Stop?? (jayden1295)
Doesn't really matter.
Old Feb 29, 2008 | 02:55 AM
wesk18's Avatar
Default Re: ¿¿Bump Stop?? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't really matter.</TD></TR></TABLE>
what is the bump stop for??
i bought some tokico blues and it came with some papers and it talks about factory bump stop has to be shorten to improve travel, is this really needed to do?
Old Mar 1, 2008 | 07:32 AM
Targa250R's Avatar
be professional
Default Re: ¿¿Bump Stop?? (wesk18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesk18 &raquo;</TD></TR><TR><TD CLASS="quote">
i bought some tokico blues and it came with some papers and it talks about factory bump stop has to be shorten to improve travel, is this really needed to do?</TD></TR></TABLE>
The bump stop is a soft limiter for compression travel. It prevents the piston at the end of the shaft inside from bottoming out, which can damage the internals and ruin the damper.
If you trim the bump stops too short, you run the risk of bottoming out the piston over large, fast bumps. A rule of thumb when running dampers with the same body length as stock is to never leave less than 1" of bump stop.
However, if the bump stop is too long, it can limit the compression travel too soon. For example, if you're running lowering springs with rates that are too soft for the ride height, the suspension can compress enough in some circumstances that the car will effectively be sitting on the bump stops - which will cause a very rough and bumpy ride, and can cause erratic handling if the suspension is running into the bump stops mid-corner.
The bump stops don't have to be shortened, but it is usually a good idea to trim at least some off if you're lowering the car. What springs are you running with the Tokico HPs?
Old Mar 2, 2008 | 12:05 AM
wesk18's Avatar
The bump stops don't have to be shortened, but it is usually a good idea to trim at least some off if you're lowering the car. What springs are you running with the Tokico HPs? </TD></TR></TABLE>
oh ok
i am putting the tokico springs i bought them together as a set!
Royal_C!ty
Northwest (Sales)
18
Apr 28, 2008 12:16 PM
AutoDB8
Mar 1, 2008 09:10 PM
socaly4life
Apr 18, 2006 03:32 PM
DFW
Aug 19, 2005 02:46 PM
DelSol-B-18
Jun 29, 2005 08:39 PM
