My N/A Exhaust Set Up
Old Feb 16, 2008 | 07:00 PM
hgem1si's Avatar
Default My N/A Exhaust Set Up
Ok so here's my issue... Searching didn't, and wouldn't really help me because I can't really focus in enough on what I'm asking.
Anyways... Right now I have a SS 4-1 Header (2.5") into an OEM cat, and 2.25" piping into a 2.25" ES-Tuning muffler.
Now I really don't know much about exhausts (hence the thread), but Should I be running 2.5" all the way back? Or at least 2.5" all the way back to my muffler?
Things to note:
-Car will never be turbo
-I plan on replacing the cat with either a high flow one, or a test pipe
-Smog isn't an issue, I have no problem bolting up a passable exhaust system
Thanks ahead of time for any help/adice, lmk if more info is needed.
Old Feb 16, 2008 | 07:01 PM
crazyguy's Avatar
Default Re: My N/A Exhaust Set Up (hgem1si)
that set up shouldnt be a problem for n/a cause i am running the smiliar set up.
Old Feb 16, 2008 | 07:02 PM
ke98248's Avatar
What you have is perfectly fine. 2.5 inch is OK, but 2.25 inch piping on an NA motor is good -- unless you are going to seriously modify the motor.. It's a nice compromise over stock exhaust piping
Old Feb 16, 2008 | 07:16 PM
hgem1si's Avatar
Default Re: My N/A Exhaust Set Up (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">What you have is perfectly fine. 2.5 inch is OK, but 2.25 inch piping on an NA motor is good -- unless you are going to seriously modify the motor.. It's a nice compromise over stock exhaust piping</TD></TR></TABLE>
I don't have a major build going, as of right now I have type-r cams. In the next few weeks I will be adding a Blox intake manifold/throttle body, and a p28. Probably gonna throw in hondata and get it on a dyno.
Thanks for the advice, I had someone telling me I would actually gain a noticeable amount of HP if I went 2.5 all the way back.
Modified by hgem1si at 8:44 PM 2/16/2008
Old Feb 16, 2008 | 07:21 PM
ke98248's Avatar
I don't think you'd notice much if any gains in HP/TQ by going with .25 inch larger piping -- but bump for more answers.
Old Feb 16, 2008 | 09:16 PM
hgem1si's Avatar
bump
Old Feb 16, 2008 | 10:11 PM
.I.Need.Money.'s Avatar
For your set-up, what you have is fine.
However, if the exhaust piping was matched to the size of your collector (2.5'') all the way back, then yes, you could pick up some power.
Old Feb 16, 2008 | 10:57 PM
hgem1si's Avatar
Default Re: My N/A Exhaust Set Up (93EGB18C1)
I think that's what I'm gonna do... A friend of mine left his old World Sport muffler in my garage, it's been like 4 months now. I think it's time for me to weld it up, lol!
Thanks for the help, I'm gonna go get my piping now! Oh yeah, and a test pipe ($$)
Old Feb 16, 2008 | 11:30 PM
mormonboy's Avatar
run a test pipe with a bung and run a blox o2 cel eliminator. that way you have minimal restrictions.
VI Boost
12
Jan 10, 2010 05:08 PM
teggy182
Mar 9, 2006 11:06 AM
92integraVTECgsr
Feb 19, 2006 07:02 PM
92integraVTECgsr
Jan 24, 2006 08:41 PM
brixity
Feb 8, 2005 02:01 PM
