wierd AND crucial electrical problem!!!
Old Feb 16, 2008 | 06:25 PM
SLeePeR-STaTuS's Avatar
Default wierd AND crucial electrical problem!!!
okay the problem is that the headlights on my hatchy (both low and high beam) don't work. Both turn signals work though. The combination light switch has been replaced, and the battery & alternator as well (alternator went bad). I also checked the under-dash fuses and they're all good! A few times though, my headlights would work out of the blue.....Thanx for all the input in advance!!!
Old Feb 16, 2008 | 06:27 PM
ke98248's Avatar
Default Re: wierd AND crucial electrical problem!!! (SLeePeR-STaTuS)
Go thru and check the headlight wiring..
You might have a frayed wire(s) or bad ground(s).
Old Feb 16, 2008 | 06:36 PM
if i have either of those, would i have 2 replace the harness, or would it be best to repair it?
moEp3
Aug 29, 2010 06:22 PM
97elitehonda
Jun 27, 2007 02:10 PM
civcexcoupeblack
Jun 23, 2003 04:34 PM
95IntegraGSRAZ
May 10, 2002 01:10 PM
KekeK-18
Jun 19, 2001 04:33 PM
