5th gen high clutch engagement
Old Feb 16, 2008 | 06:00 PM
Inextricabledrvr's Avatar
Default 5th gen high clutch engagement
Lately Ive been noticing a difference on the engagement of my clutch. It has been engaging alot higher than normal. I pretty much have to release the pedal all the way to engage.
Should I just adjust my clutch pedal or is my clutch going out.
Old Feb 16, 2008 | 06:34 PM
JasonST's Avatar
Default Re: 5th gen high clutch engagement (Inextricabledrvr)
As clutches wear the engagement point gets higher and higher, but till it goes out u can just adjust it through the adjustment bolt on the pedal/clutch master cylinder.
Old Feb 16, 2008 | 06:54 PM
Default Re: 5th gen high clutch engagement (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">As clutches wear the engagement point gets higher and higher, but till it goes out u can just adjust it through the adjustment bolt on the pedal/clutch master cylinder.</TD></TR></TABLE>
Thank you
Old Feb 16, 2008 | 07:02 PM
dagle's Avatar
check your brake fluid in your MC's resorvoir.. that could be partially to blame
Damndislaosboy
Feb 13, 2008 05:00 PM
crazyguy
Jun 8, 2007 01:16 PM
Boostin_GSR
Jun 3, 2007 11:34 AM
LSEGHATCH
May 2, 2006 06:18 AM
MrSmith
Sep 28, 2001 08:30 PM
