h23 swap
Old Feb 16, 2008 | 05:17 PM
2ndchirp's Avatar
Default h23 swap
For a few days now me and a friend took out the h23 out of his 1992 prelude si which was automatic with a bad engine and we swaped another H23 and a manual trans...it was a success and everythin worked fine but there is a wierd problem... when the engine turns on cold it idles at 2,000 rpms like normal but after it heats up it starts surging and it keeps going even after we drive it.. i want to kno what can cause the surging on that engine.. an iac valve? fast idle? vacumm leak??
Old Feb 16, 2008 | 08:30 PM
98vtec's Avatar
moderator emeritus
Default Re: h23 swap (2ndchirp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote"> an iac valve? fast idle? vacumm leak??</TD></TR></TABLE>
sounds like you already know what you need to do.
Old Feb 17, 2008 | 06:32 AM
vlang29's Avatar
https://honda-tech.com/zerothread?id=1979500
Old Feb 17, 2008 | 09:38 PM
2ndchirp's Avatar
Default Re: h23 swap (vlang29)
thanks!!!!
preludercr
Dec 26, 2008 10:53 AM
h23prelude94
Dec 15, 2008 03:45 PM
oes
Oct 4, 2003 06:40 PM
CaNaBiS
Sep 26, 2002 05:19 AM
