crappy startup?
Old Feb 16, 2008 | 03:43 PM
bentegrity's Avatar
Default crappy startup?
well a couple of days ago, getting out of work for my lunch break before getting on my second shift since i was working a double. get to my car, turns over just fine, but no start. cranks and cranks and cranks, no good. coil went out. instead of picking up food, i literally run down to an advance auto parts and pick up a new coil, switch it out in the parking lot, and of course it starts right up the best and fastest it ever has.
days go by, and soon enough, it starts giving me the crappy start up it used to; to where it doesn't immediately start up, but takes a while (even with giving the fuel pump time to prime).
it seems as if some how, the coil is draining power or something, all grounds are good, so idk what would be doing this. of course, if i drive it around, turn it off and leave it for about half and hour or so, and turn it back on, it turns on fine. it only gives me the crappy start up basically after sitting for a while (like overnight or something).
any ideas?
TIA
Old Feb 16, 2008 | 11:00 PM
slowassgsr's Avatar
Have you checked the spark plugs and wires?
Old Feb 16, 2008 | 11:11 PM
Jimmy's Avatar
Global Moderator
Default Re: crappy startup? (bentegrity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bentegrity &raquo;</TD></TR><TR><TD CLASS="quote">
Do you mean as soon as you turn the key over to start it nothing happens at all, or it just cranks over??
If nothing at all is happening when you turn the key on to start it.. i'd check the ignition switch
Old Feb 17, 2008 | 10:22 PM
bentegrity's Avatar
Default Re: crappy startup? (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
If nothing at all is happening when you turn the key on to start it.. i'd check the ignition switch</TD></TR></TABLE>
it just cranks over with no ignition. i'm guessing then it should probably be bad wires and plugs. i forgot the toll HPDE events will do my fault for believing NGK iridiums would be better in the "longer-lasting" area. thanx gaise.
Briandavis
Nov 23, 2017 05:00 PM
alexdbest
Honda CR-V & Element
12
Dec 23, 2013 03:55 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
zennx2k3
Sep 23, 2008 05:38 AM
TurboedGSR
Sep 18, 2002 05:23 PM
