B16B in a '94 EG.. Was told NOT to use B16b harnes?!? Look inside, i need advice
Old Feb 16, 2008 | 03:23 PM
unified112's Avatar
Default B16B in a '94 EG.. Was told NOT to use B16b harnes?!? Look inside, i need advice
Ok, a buddy of mine had a B16b swap in a '98 EK, but sadly someone rear-ended him and totaled the car.
His thoughts are putting the R into an '94 EG hatch. He has the entire engine harness, we disconnected it and pulled it through the firewall. However, a friend of his told him that the harness won't work 'because of the gauge setup, they're different. get a obd1 sohc ex or a '94-'95 gsr harness'
I don't recall disconnecting anything other than three plugs from the ecu, and those three plugs went with the harness, no dash attachments, nothing. So, I was wondering how using the B16B harness would be a bad thing? Using the obd2 harness, with its original ecu.. i don't see the issue. Can anyone enlighten me please?
Old Feb 16, 2008 | 04:38 PM
v4lu3s's Avatar
RTFM
it does not fit. your friend is right. obd2 engines the harness goes from engine to ecu....obd1 car the engine harness goes from strut tower to strut tower and connects to the firewall harness.
Old Feb 17, 2008 | 09:13 AM
projectTeG's Avatar
wont work because of the difference in years, plug styles. just use you stock harness and lengthen where you need it and use the plugs from the B16b harness if you need to. FYI i have a 98 gsr in a 91 teg using my obd1 harness with vtec spliced in.
Old Feb 17, 2008 | 09:26 AM
saleensolution's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">it does not fit. your friend is right. obd2 engines the harness goes from engine to ecu....obd1 car the engine harness goes from strut tower to strut tower and connects to the firewall harness.</TD></TR></TABLE>
x2
Old Feb 17, 2008 | 11:01 AM
unified112's Avatar
Cool, cool. I appreciate the feedback guys.
Old Feb 17, 2008 | 04:33 PM
chad's Avatar
Moderator
Default Re: (unified112)
get an OBD2b engine harness from a Type arrrrrrrrr and everything will plug onto the b16b engine and then plug straight into the eg factory shock tower wire harness
jaelynrei
13
Sep 15, 2014 10:53 AM
honda_hackett
Nov 25, 2008 01:17 PM
jdmekrobot
Mar 13, 2008 12:13 AM
EF7
Sep 25, 2006 09:06 AM
endlessdv
Feb 6, 2005 04:16 PM
