won't start
car will not start, pulled the starter out tested it and it was bad. Replaced the starter, still won't start. Checked for spark and wasn't getting any, replaced with new distributor, still no start. I have checked all grounds and fuses all are good, there is power going to the starter but the car just clicks repeatedly at the distributor, does anyone have any clues on what it could be. Engine is OBD-0 B16A. Thanks
Sounds like your new dizzy either is bad or plugs not connected. No spark is either the coil, which is in your dizzy or the ignitor which is in your dizzy also.
How did you check for spark anyways?
vizsual00
Mar 20, 2005 01:49 PM
, then slap yourself when you re read your post and notice where you screwed up!
