Car won't start: need help asap
jump start to make sure its not the battery. if it isnt then ,turn key to acc postion and listen to hear if the fuel pump primes. if it doesnt, replace the main relay.
In order to start, the clutch must be depressed the whole way. There is a switch on the clutch pedal mount that must be depressed. It is up under the dash.
Part 17
http://www.sonsacuraparts.com/...dIrno=
The switch could be loose or failing. Check the contacts for continuity both depressed and released.
BTW, do you have an alarm with a starter disable?
Part 17
magicmyst98
14
Sep 2, 2013 12:06 PM
PaulHuston
Mar 18, 2007 11:16 AM
