anyone know how to wire in the v-afc apexi converter
Old Feb 16, 2008 | 08:32 AM
usdm-ef9's Avatar
Default anyone know how to wire in the v-afc apexi converter
ive got a 91 civic hatch wit the jdm b16a obdo motor in it! can anyone help? i have the pw0 ecu also!
Old Feb 16, 2008 | 09:08 AM
Crx Jimmy's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (usdm-ef9)
Why dont you buy a plug and play jumper harness for the v-afc, so it just plugs in
http://vtecfrog.com/Web_Pages/V-AFC.html
Old Feb 16, 2008 | 09:16 AM
usdm-ef9's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (Crx Jimmy)
u know how much that is? and i already repined my ecu and everything works fine. and now ive gotten this apexi v-afc and wanted to wire it in!
Old Feb 16, 2008 | 10:32 AM
nihad's Avatar
try to search on google for the vafc pin diagram for a civic u should be able to find some thing on it it like 7 wires it not hard.
Old Feb 16, 2008 | 10:36 AM
gibsanez's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (nihad)
Why don't you just get the car dyno tuned like a real car?
Old Feb 16, 2008 | 12:26 PM
Tippyman's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just get the car dyno tuned like a real car?</TD></TR></TABLE>
Then you won't have a cool light up thing on the dash.
Old Feb 16, 2008 | 01:20 PM
gibsanez's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Then you won't have a cool light up thing on the dash.</TD></TR></TABLE>
****, what happens when my car gets teleported back to 2000 and i have no blinky things in my car?
Old Feb 16, 2008 | 01:26 PM
usdm-ef9's Avatar
dude shut up! this site is for people 2 ask 4 help not b a douche! obdo is better than obd1 or 2! way easier to work on and find the problem. so just shut up an dont replie if u can't help out somebody! thanks dustin
Old Feb 16, 2008 | 01:30 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm-ef9 &raquo;</TD></TR><TR><TD CLASS="quote"> obdo is better than obd1 or 2! way easier to work on and find the problem. </TD></TR></TABLE>
You just defeated yourself.
msinsky14's Avatar
apexi's website has a diagram for this. but to let you know, obd1 is the easiest and has the most options for tuning. trust me, if u want to seriously tune your car convert it to obd1 and get it dyno tuned
Old Feb 16, 2008 | 01:48 PM
usdm-ef9's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (msinsky14)
they have it for a del sole but not the 91 civic on apexi unless u have a diffrent link that shows that, cause i cant find it!
Old Feb 16, 2008 | 08:02 PM
msinsky14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm-ef9 &raquo;</TD></TR><TR><TD CLASS="quote">they have it for a del sole but not the 91 civic on apexi unless u have a diffrent link that shows that, cause i cant find it! </TD></TR></TABLE>
just find out what pins are for the del sol one and splice it into the same wires for your ecu. its not that hard bro
Old Feb 16, 2008 | 11:11 PM
424racer's Avatar
maybe this will help...
http://www.apexi-usa.com/support_wiring.asp
or
http://www.apexi-usa.com/support_installation.asp
Old Feb 17, 2008 | 04:20 AM
Grandhustleman86's Avatar
HA HA....dood just run the PnP harness....do it right dont cut splice and solder....looks shitty IMO....lighten up man.
Old Feb 17, 2008 | 04:21 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm-ef9 &raquo;</TD></TR><TR><TD CLASS="quote">dude shut up! this site is for people 2 ask 4 help not b a douche! obdo is better than obd1 or 2! way easier to work on and find the problem. so just shut up an dont replie if u can't help out somebody! thanks dustin</TD></TR></TABLE>
Alright, since you want "help", here's some.
First of all, OBD1 is a superior system to OBD0. There are more tuning options, more ECU aftermarket support, and the tuning systems tend to be superior to the OBD0 offerings.
Second, a chipped ecu running something like crome/hondata or something similar will be a much easier to tune with rather than your piggyback system. Are you even having the car dyno tuned? Or are you just gonna change your b-tak point or try to add/remove fuel blindly?
Do you even have enough done to the engine that would necessitate a tune?
Old Feb 17, 2008 | 09:01 AM
usdm-ef9's Avatar
thats ur opinion not mine i happen to like the obdo system better. plus it orignal, so just dont post on my thread if u cant help out thanks
Old Feb 17, 2008 | 09:05 AM
Tippyman's Avatar
Lol.
Old Feb 17, 2008 | 09:09 AM
zccr-xsi's Avatar
wow i didnt know pepole still use VAFCs!thats old school ****
Modified by zccr-xsi at 10:36 AM 2/17/2008
Old Feb 17, 2008 | 09:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm-ef9 &raquo;</TD></TR><TR><TD CLASS="quote">thats ur opinion not mine i happen to like the obdo system better. plus it orignal, so just dont post on my thread if u cant help out thanks</TD></TR></TABLE>
I know man...wow.
Look man check out Boomslang.us they have a PnP harness for your VAFC....its pretty cheep too....I understand you dont wanna do it this way but sometimes your just better off in the end.
OBD1 FTW
Old Feb 17, 2008 | 09:35 AM
zccr-xsi's Avatar
Default Re: anyone know how to wire in the v-afc apexi converter (Grandhustleman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grandhustleman86 &raquo;</TD></TR><TR><TD CLASS="quote">
OBD1 FTW
x2
yea obd1 is the best to use,cause theres neptune,crome pro and ectune which i think one day with over take crome.
Old Feb 17, 2008 | 11:04 AM
gibsanez's Avatar
A chipped ecu running something like crome/hondata or something similar will be a much easier to tune with rather than your piggyback system. Are you even having the car dyno tuned? Or are you just gonna change your b-tak point or try to add/remove fuel blindly?
Do you even have enough done to the engine that would necessitate a tune?</TD></TR></TABLE>
Old Feb 18, 2008 | 05:01 PM
usdm-ef9's Avatar
does anyone know how to do this or not!??? plz i dont want the pnp harness it's like 200 dollars!
Old Feb 18, 2008 | 05:08 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Are you even having the car dyno tuned? Or are you just gonna change your b-tak point or try to add/remove fuel blindly?
Old Feb 18, 2008 | 09:05 PM
msinsky14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm-ef9 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to do this or not!??? plz i dont want the pnp harness it's like 200 dollars!</TD></TR></TABLE>
first of all our "opinions" on which obd is better isnt an opinion. try tuning an obd0 vs. obd1 and see how much aftermarket support there is. many more companies offer tuning software and almost no reputable tuning shops tune obd0 ecu's anymore.
like i said in the earlier post, find out which wire is supposed to connect where on the del sol vtec, and splice it into the wires for the same function on ur ecu. its not that hard dude.
good luck
Old Feb 18, 2008 | 09:54 PM
nihad's Avatar
just get a b16a ecu for obd0 there u go vtec kick in yo ha.
