Honda/Acura B and D series Compression Calculator
Old Feb 16, 2008 | 12:07 AM
Killer Kham's Avatar
Default Honda/Acura B and D series Compression Calculator
This calculator is intended for use as a general estimate of your compression only. Certain variables that cannot be accounted for may cause the actual compression ratio to vary - such as a head that has been milled. Please use your own descretion.
Default values have been provided for your convenience. You can enter your own custom values in the edit boxes below to match your personal setup as needed.
http://www.c-speedracing.com/h...c.php
Old Feb 16, 2008 | 12:41 AM
Froth's Avatar
Default Re: Honda/Acura B and D series Compression Calculator (Killer Kham)
https://honda-tech.com/zerothread/1998336
Ctrl + F and type in "compression"
-Froth
Old Feb 16, 2008 | 02:43 AM
Default Re: Honda/Acura B and D series Compression Calculator (Froth)
Thanks, that is even better
kill bill
Mar 26, 2003 11:52 AM
gsrteg
Aug 22, 2002 08:35 PM
