h22 wont pass 6500
Old Feb 15, 2008 | 11:49 PM
BB1LOViN's Avatar
Default h22 wont pass 6500
for some reason, my h22 wont rev past 6500. i know redlines at 7500.
anyone else ever have this experience??
the rpms just stopped at6500 through 1st and 2nd, it feels as if i was hitting the rev limiter.
Also i heard "bangs" likes the sound of a gunshot..but that could just be my little hole in my exhaust pipe/ restrictive twinloop muffler.
Old Feb 15, 2008 | 11:57 PM
BB1LOViN's Avatar
Default Re: h22 wont pass 6500 (BB1LOViN)
after my searches: others have wrote
to check vtec oil and sensor.
or to rewire my vtec?
where can i check my "vtec oil" ive never heard of that.
Old Feb 15, 2008 | 11:58 PM
viper_boy403's Avatar
was it warmed up all the way? meaning, had the temp gauge moved up at all? (when the t-stat opens) Also check your oil level
BB1LOViN's Avatar
could it be that when i switched my timing belt, the vtec wiring was effected??
Old Feb 15, 2008 | 11:59 PM
BB1LOViN's Avatar
Default Re: (viper_boy403)
yeah i had oil and also the car was at optimum temp
Old Feb 16, 2008 | 04:12 AM
vlang29's Avatar
Default Re: (BB1LOViN)
CHECK ENGINE CODES
Old Feb 16, 2008 | 07:06 AM
93lxh22's Avatar
Default Re: (vlang29)
what ecu do u have? when i had the p13 it did that and i was told to get a chipped ecu. so i got a chipped p28 in mine problem was fixed
Old Feb 16, 2008 | 08:14 AM
vlang29's Avatar
dude... if your p13 rev limits at 6500, the ecu is in limp mode, because of a trouble code!! and i just bet your check engine light is on...
read and do this:
http://www.superhonda.com/foru...44813
write back and tell us which codes come up.
Old Feb 16, 2008 | 10:54 AM
JrSr2003's Avatar
1. It's limp mode cause you have a cell code...
2. Check your oil. You might be running low...
Old Feb 16, 2008 | 11:51 AM
BB1LOViN's Avatar
Default Re: h22 wont pass 6500 (vlang29)
for some reason, my check engine light isnt on.
i checked my oil and all was fine.
i have the stock p13 ecu
Old Feb 16, 2008 | 11:53 AM
BB1LOViN's Avatar
thanks for the link.
so if i had a code say "23" the CEL would blink 23 times?
Old Feb 16, 2008 | 12:18 PM
possibly clean your vtec solenoid, the screen may be clogged.
Old Feb 16, 2008 | 12:28 PM
dagle's Avatar
no to check ur CEL 23 would be 2 long blinks and 3 short blinks
Old Feb 16, 2008 | 02:33 PM
vlang29's Avatar
Default Re: (dagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">no to check ur CEL 23 would be 2 long blinks and 3 short blinks</TD></TR></TABLE>
Old Feb 16, 2008 | 06:39 PM
JasonST's Avatar
ur CEL light isn't on? Does it come on when u're about to start the car? If not than the lights broken. If it is on and u *don't* have a cel than look into things like grounds. I had a problem where my h22 redlined at 6500 rpm because of a loose ecu ground, but that was my case and might be a different case for u. But still something to look into.
Old Feb 16, 2008 | 09:44 PM
BB1LOViN's Avatar
Default Re: (JasonST)
thanks for all the info guys/girls!
i do have a CEL light, its not broken.
today i checked my vtec solenoid and it was okay
my mechanic/friend says it might be the valve?idk what valve he was talking about though.
Old Feb 17, 2008 | 08:16 AM
MikeLuder's Avatar
make sure ur oil pressure/vtec solenoid are wired correctly, in my case i had them wired up, but backwards. there was NO CEL, and vtec would not open completely, thus red lining at 6500rpms. Believe it was the secondaries opening up, so you hear a slight roar where vtec is supposed to be.
You may not completely be in 'limp' mode if you have no cel.. if car runs fine jst until vtec, you definitely have a wiring issue, or like someone else said obove, your solenoid could be clogged. Just clean it to rule it out. Hope this helps!
Old Feb 18, 2008 | 04:58 PM
BB1LOViN's Avatar
Default Re: (MikeLuder)
my mechanic said it might be the ecu??
as 93lxh22 said "what ecu do u have? when i had the p13 it did that and i was told to get a chipped ecu. so i got a chipped p28 in mine problem was fixed"
is this possible??
is there any easy way i can check the vtec wiring?...i honestly have no idea as to what it even looks like
Old Feb 18, 2008 | 05:01 PM
BB1LOViN's Avatar
would my vtec wiring be incorrect if all i did was a timing belt swap?
i have the standard h22a1 btw..no swap, so im assuming my ecu is a p13
Old Feb 18, 2008 | 05:06 PM
BB1LOViN's Avatar
is it still safe for me to drive this way?
Old Feb 19, 2008 | 05:58 PM
Extradition's Avatar
You should be able to drive it still, but maybe a diagnostic tool will let you know what's going on better...?
Old Feb 19, 2008 | 06:06 PM
shaylude's Avatar
you shouldn't have any problems, just don't get on it.
Old Feb 19, 2008 | 07:13 PM
BB1LOViN's Avatar
Default Re: h22 wont pass 6500 (Extradition)
thanks for the info everyone
will a diagnostic tool show my exact problem? even without having my CEL light pop up??
*noob question* but is there anyway to check if my ecu is really malfunctioned?
and are there any other alternatives instead of getting another p13?
Old Feb 20, 2008 | 10:19 PM
BB1LOViN's Avatar
called the local Honda for the hell of it and they said a new p13 would run me $954.55
JPR motor inc. says theyll sell me a JDM p13 for $250
i have a USDM H22a1.
Will the JDM p13 plug and play without a tune? is vtec sitll at 5200?
Old Feb 21, 2008 | 05:03 AM
mattsnooz's Avatar
JDM ecu's have rev limiters on them don't they? or is that just h23s? (P14s)
You should stick to usdm. and stick to exact model numbers as your proper* ecu should be!
Try to buy a cheap one P13($100) (it will work if you get it from right person off
H-T) If the same problem persists than its not your ecu.
Don't buy from the stealership!!!! H-t has somewhat of a marketplace.
Its not your ecu though I wouldn't think. But like I said, 100 dollars will let you know. And its always good to have an extra ecu kicking around to perhaps socket, and try different tuning chips (good ones, lol if there are any) by a quick swap of ecu's.
Its probably a sensor. So you've jumpered your little blue connector in the center of your dash, and your not getting any check engine light? The engine light should come on, but will blink if theres a cel. Some Cels don't come on unless you check for them. IF your engine light never comes on while starting up than your ecu might be fu*ked!!
