Freakish Oil leak on 97 lude
Old Feb 15, 2008 | 11:45 PM
pdgreen's Avatar
Default Freakish Oil leak on 97 lude
Ok guys, I have an oil leak on my car that only occurs when the car is running. we replaced the filter and checked for a double seal. no problem there. it doesnt leak when the car is off, but as soon as you start it, it gushes oil. it almost seems like its coming from a spot somewhat next to where the oil filter screws on. and its only coming from the spot. I took it to a shop and they said they couldnt find it just by looking at it, so they say they have to lift the engine out which just that will cost me 900. does anybody have any ideas what this could be. the car is a 97 Prelude SH. not sure engine model exactly but it is the original engine in the car. Thanks for reading and thanks in advance for any help you can give me.
Old Feb 16, 2008 | 04:15 AM
vlang29's Avatar
Default Re: Freakish Oil leak on 97 lude (pdgreen)
Almost 100% sure it's the oil cooler seal. Goes in between the oil cooler and block. I had to replace this one, it's very common to go out.
Old Feb 17, 2008 | 07:35 PM
Pussy_magnet_00's Avatar
or oil pressure sensor, its back there too and could leak
Old Feb 17, 2008 | 07:50 PM
EFz6er's Avatar
Default Re: (Pussy_magnet_00)
oil cooler o-ring guar anteed
Old Feb 17, 2008 | 07:51 PM
bluedlude's Avatar
should be an easy fix if you search for oil cooler o-ring. man, that mechanic must be dumb as a rock.
Old Feb 17, 2008 | 11:55 PM
ne4spe's Avatar
Default Re: (bluedlude)
yeh man he sure must be pretty dumb or he is just trying to scam you! im 99.9% sure it is the oil cooler o ring. cuz i have had the same leak and they also tried to rob my girl when she took my car to the shop. but then i looked and that took less than 15 min to change.
Old Feb 18, 2008 | 02:26 AM
97lude's Avatar
Default Re: (EFz6er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er &raquo;</TD></TR><TR><TD CLASS="quote">oil cooler o-ring guaranteed</TD></TR></TABLE>
had the same problem
Old Feb 22, 2008 | 06:52 PM
pdgreen's Avatar
does anyone know how long it takes to do this , and whether its best to do it from the top or underneath?
Old Feb 22, 2008 | 08:17 PM
bluedlude's Avatar
you do it the same way you would change your oil filter. from underneath the car. you will need a 30mm socket to get the nut that holds the cooler on loose. should take you a couple minutes, the longest part is waiting for the oil to drain.
remove your oil filter. put the 30mm socket on the bolt where the oil filter was. take the bolt off and remove the oil cooler. replace gasket then the cooler then the bolt. put the filter back on and refill your oil
kid.dynamite
Jan 24, 2016 09:32 AM
JustCant5topMe
Aug 16, 2013 12:18 PM
koreanboi
Feb 21, 2008 06:13 PM
daksxt2002
May 10, 2007 07:33 AM
