GSR wire harness
I have a couple quick questions that hopefully some of you integra gurus can answer off the top of your head. I am swapping a h22/f22 frankenstein in a 94 GSR chassis. I'm starting on the wiring harness and I dont want to chop up the chassis wiring harness. So I was considering 2 options:
1. Buy an integra wiring harness and modify it to fit my motor.
2. Try and get the connectors I am missing and modify the harness I have
Either way I would like to know what harnesses have the right connectors to plug into the chassis harness? I have 1 or 2 of the main plugs that fit but I still need 3 or so more. I was wondering if all B-series used the same connectors to connect to the chassis or not. Also I can't find any information showing a pinout of all those connectors under the hood. I assume almost all of them connect to either the gauges or the ECU although I haven't been able to find anything that says exactly what they do yet. So if anyone knows where to find some of that information it would be helpful also, Thanks!
OK, I got a second hand to help me out which made it pretty simple to just trace the wires. I wrote down everything on a separate sheet of paper so I'll probably post that in this forum so any future h22 swappers don't even have to trace any wires. Anyhow, on to my next question.
Does anyone know where I can get the main engine harness connectors(engine side, aka male end). I need the smaller 10 pin that connects on the passenger side of the engine bay and also I need the engine side(female) coil connector. It doesn't look like you can order just the connector on majestic or slhondaparts or I can't find it on there.
Rusty Shackleferd
Jan 25, 2005 11:28 AM
GoodGasMileage
May 21, 2003 08:44 AM
