02 Accord Stumbles upon cold start....
Old Feb 15, 2008 | 09:24 PM
Adro01982's Avatar
Default 02 Accord Stumbles upon cold start....
Hi all,
I have 2002 Honda Accord SE 4cyl that stumbles (misfire) when the engine is completely cool (ie cold starts when warm or hot acts just fine) no check engine light only started acting up at 96k miles...This condition lasts like 7 seconds and then the engine catches itself...If I Press the gas pedal while attempting a cold start the car starts normally (without stumbling or missing) albeit at a higher rpm at start...Any info would be appreicated...Adro
Old Feb 16, 2008 | 10:11 AM
hondadude's Avatar
Default Re: 02 Accord Stumbles upon cold start.... (Adro01982)
Try this; turn the key on and wait 5 sec before cranking.
This allows for full fuel pressure at the injectors and a better spray pattern.
Original spark plugs?
Old Feb 29, 2008 | 04:52 PM
Adro01982's Avatar
Default Re: 02 Accord Stumbles upon cold start.... (hondadude)
Yes It is the original Spark plugs got 96k on 'em? guesssing its time to change them?
Old Feb 29, 2008 | 06:36 PM
steerh67's Avatar
yes, change those plugs. don't buy anything fancy, just get the same plugs that you take out of it, they're work just fine.
crook803
Nov 18, 2017 04:36 PM
Tish Viscious
Jan 24, 2016 09:19 AM
Dadragonlord289
Jan 25, 2015 03:17 PM
dynomax666
Mar 23, 2009 01:40 PM
luketrot21
Nov 1, 2003 12:21 PM
