Question!! Can I Use A D15b7 Head On A D16y7 Block??
Old Feb 15, 2008 | 07:24 PM
gotboosthatch's Avatar
Default Question!! Can I Use A D15b7 Head On A D16y7 Block??
hello, can i put a d15b7 head on a d16y7 block?
i have a b7 head laying around and i bent valves on my y7 head so im wondering if i can use that head.?
any answers would help a lot.. thanks
if it can work which headgasket would i need and timing belt/ head bolts to use?
thanks a lot
Old Feb 15, 2008 | 08:10 PM
upp...help
Old Feb 15, 2008 | 09:51 PM
ddd4114's Avatar
Default Re: (gotboosthatch)
Yes, use the z6/y7/y8 MLS OEM gasket. I'm not sure about the head bolts, but I imagine that you'll need a d16z set.
Old Feb 15, 2008 | 09:54 PM
y z6? im not even using any part of that motor?
Old Feb 15, 2008 | 10:00 PM
ddd4114's Avatar
They all use the same head gasket.
EDIT: However, ask for a y7/y8 MLS OEM gasket at your Honda dealer. It will be cheaper.
Old Feb 15, 2008 | 10:21 PM
i know about the headgaskets im wondering about the timing and the cam gear
Flareside302
Jun 24, 2015 09:58 PM
Syke909
Jun 19, 2013 04:12 PM
92superhb
May 2, 2006 05:28 PM
