HELP MOTOR OUT OF TIME
Old Feb 15, 2008 | 06:39 PM
rbpwrd240's Avatar
Default HELP MOTOR OUT OF TIME
Ok guys my friend took off the timing belt on his B16A crx and when putting it back on the intake cam moved. My question is how do i get them back in time with the crank i know that the pink notch lines up with the notch on the outer cover and that the cam marks go to top but i did that and the valve train on the intake side is making noise. Please let me know what i can do to ensure everything is back in time.
Thanx
Old Feb 15, 2008 | 11:27 PM
rbpwrd240's Avatar
Default Re: HELP MOTOR OUT OF TIME (rbpwrd240)
bump
Old Feb 24, 2008 | 08:32 PM
rbpwrd240's Avatar
I still need help with this guys, I dont think its as easy as aligning the cams and putting the crannk at TDC at cylinder number 1 is it?
Old Feb 25, 2008 | 01:50 AM
traxxasx's Avatar
just put everything at TDC and put the belt on. There should be marks where the oil pump and crank should line up to.
But yea EVERYTHING TDC and you be good to go.
Old Feb 28, 2008 | 09:50 AM
rbpwrd240's Avatar
Default Re: (traxxasx)
Sorry to act like such a noob but i want to do it right the first time. So the cams dont have to be on an intake or exhaust side they just need the arrows to point at each other and up and the crank needs to be at TDC for cylinder number 1?
EKB18BPR3
Oct 28, 2021 03:54 PM
M ST.
Jun 1, 2010 02:03 PM
B18EG6
Jan 13, 2006 11:02 AM
sik96teg
Apr 19, 2005 07:51 PM
MUGENTYPER
Jul 1, 2002 07:26 PM
