EF guys Stock crossmember? possible downpipe? Which way to run the turbo
Old Feb 15, 2008 | 02:55 PM
EF9ZC's Avatar
Default EF guys Stock crossmember? possible downpipe? Which way to run the turbo
hey guys I've been looking around on the forum for awhile now and I just can't seem to find the right answers to some of my questions. I have a 91 CRX si with a jdm b16a with hasportmounts. I have been piecing together a turbo kit for a little over 6 months and now that I am getting closer then ever I really just need the answers to a few question I'm going to run a old inline pro log style manifold with a garrett t3 t4 57trim 63ar. before i boost it I need to no a few things hopefully you guys will be able to help me out without yelling SEARCH at me. any help would be much appricated.
1,will I be able to get a downpipe made for my car without running a aftermarket crossmember or notching the crossmember? If notching how safe is it? how much to cut out.
2.What size piping would I be able to run safely? 3, 2 1/2?
3. which way would be easier to run the downpipe. With the exhaust side of the turbo facing the driverside or the passenger side.
hopefully boosted one of these days .... chris
Old Feb 15, 2008 | 03:11 PM
Minor Threat's Avatar
Default Re: EF guys Stock crossmember? possible downpipe? Which way to run the turbo (EF9ZC)
I ran a 3inch DP on the passenger side with a stock crossmember on my old EF.
Which side you should put it on really depends on your manifold selection, some place it too far out depending on which way the turbine is oriented.
Old Feb 15, 2008 | 03:28 PM
EF9ZC's Avatar
what do you mean by turbine oriented?
Old Feb 15, 2008 | 03:37 PM
Default Re: (EF9ZC)
Compressor on the drivers side would make the turbine offset away from the block, and vice versa.
Depending on which way you want it to face, the offset may place the turbo too far out from the block, or too close to it, depending on where the turbo flange is located in the engine bay.
Make sense?
Old Feb 15, 2008 | 03:47 PM
EF9ZC's Avatar
yea that makes sense. So you think i could run my turbo with the exhuast housing facing the passenger side running a stock crossmember, without notching the crossmember correct?
Old Feb 15, 2008 | 04:47 PM
sirtef9's Avatar
Default Re: (EF9ZC)
I have a 2.5 inch exit facing passenger side, and I already had my front mount cut off the cross member, if It was'nt I don't think it'd fit to well. Your more then likely gonna lose your windshield washer fluid resevoir. O well though its all in the name of "BOOST"
Old Feb 15, 2008 | 04:50 PM
EF9ZC's Avatar
haha any other opions
Old Feb 15, 2008 | 07:34 PM
T9U4ReBgO's Avatar
Default Re: (EF9ZC)
get traction bars..it will solve alot of problems...I have a 2.5in dp on my ef and had to cut the crossmember now I have traction bars and I can fit 3in easily and can set my radiator in factory position...
Old Feb 15, 2008 | 09:05 PM
EF9ZC's Avatar
any one elses experience
Old Feb 15, 2008 | 10:27 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
etd has traction bars for 250 dollars. get the traction bar and you wont have any clearance issues and no wheel hop.
pcguy760
Jul 12, 2008 12:39 PM
1badteg
Oct 21, 2007 01:45 PM
NotPhilTran
Nov 11, 2003 10:01 AM
Frcfedintegra
Jul 24, 2002 11:15 AM
