H-T: Damage Estimate
Old Feb 15, 2008 | 02:17 PM
ezekiel1059's Avatar
Default H-T: Damage Estimate
So, on my way to work this morning, I got into a little accident on the way to work. Rear ended a Matrix on an onramp going about 15-25 mph. Seeing if I can get help on what total damages are.
Please no negative comments.
What it looked like:
Damages (sorry for bad pix, crappy work digi cam):
Old Feb 15, 2008 | 02:22 PM
The Collin's Avatar
Depending on what you want to do with it now, only a few hundred. The hood is fixable and repaintable. New headlight since the tabs are broken, new grille and some reworking to get parts to fit. Definitely not going to break the bank.
Old Feb 15, 2008 | 02:29 PM
Regal's Avatar
Ladies and gentlemen we are floating in space...
Default Re: (99_hb_on_air)
It looks like he needs a new radiator support welded in too, though. Maybe I'm seeing it wrong?
Old Feb 15, 2008 | 02:32 PM
Ep1dem1c's Avatar
Default Re: (Regal)
rad support off ebay: $100
Hood (used): $50
Headlight (if you want to replace it): $50 (used)
Front Bumper: $125
Paint: $200
Total: $525
Check from insurance well over $1000 probably
The Collin's Avatar
possibly, it's kind of hard to tell. But the rad support doesn't look creased or too banged up. I think it could be pulled and straightened out? Good luck!
Old Feb 15, 2008 | 02:34 PM
Not to sure about the radiator support. I might try to take a come-a-long to it and see if that will bring it back.
Old Feb 15, 2008 | 02:59 PM
iBear's Avatar
Default Re: (ezekiel1059)
Ouch.
Doesn't seem too bad from what I see. As long as the radiator support isn't too banged up.
Old Feb 15, 2008 | 03:00 PM
matt j's Avatar
it all depends on what you want to do. do you want to go a cheaper route? or do you want to do it right?
you could do a jdm front end on it that includes the radiator support for just a few hundred dollars. or you can order it all piece by piece and it end up costing alot more money.
Old Feb 15, 2008 | 03:31 PM
jiggatone's Avatar
just go to the junk yard ull spend lesser then 100 for all that **** hood,light,bumper,grill.
Old Feb 15, 2008 | 03:42 PM
GG99's Avatar
Default Re: (jiggatone)
take that insurance check and buy a airwalk bumper lol
Old Feb 15, 2008 | 04:22 PM
Andyroo's Avatar
just get a new hood, grill and get the frame part pulled back out no biggy
Old Feb 15, 2008 | 04:32 PM
Crank's Avatar
Default Re: (Andyroo)
looks like u only need to replace the "T" section of the radiator support. about $150 new from honda.
Old Feb 15, 2008 | 05:05 PM
thanks for all the suggestions. I will take it apart this weekend and really check out the damage. The "T" section does not look damaged at all, but I will find out for sure. thanks again.
Old Feb 15, 2008 | 05:06 PM
RC_Marshall's Avatar
Default Re: (Crank)
dosent look bad at all
Old Feb 15, 2008 | 10:16 PM
VNY_Khmer's Avatar
Default Re: (RC_Marsh)
joi.
Old Feb 15, 2008 | 10:22 PM
96 EJ8's Avatar
Default Re: H-T: Damage Estimate (ezekiel1059)
not bad at all, you can do it all yourself and it will run you with paint about $500-$600.
good time to upgrade to a CF hood
baonest
Mar 5, 2008 05:52 AM
dilie
Jun 30, 2006 06:01 AM
EG2 SiR
Aug 2, 2003 10:16 PM
fastwanabe
Oct 22, 2002 07:50 PM
