Anyone want to post pics of there exhaust ?
I'm looking for pics of:
1)Greddy SP2 on CRX
2)Apexi WS on CRX
I'm not crazy about all the web store having the cat back exhaust kits but with NO pics on the acual car. The Greddy says its a sideways mount set up, similar to a Invidia set up I suppose. I searched the net and could not find any pics of those 2 on a CRX and I even looked on You Tube for videos of CRX with those. I just finished installing my b16a/LSD combo but now need a new exhaust since car was a 1991 HF and well need new exhaust.
Thanks.
1)Greddy SP2 on CRX
2)Apexi WS on CRX
Thanks.
89s1...I did that and all you get is images of the muffler and pipes...not the CRX back bumper with the tail pipe or pic of the kit mounted from underneath the car. Like I said I looked , I may be new here but NOT new to searches.
I'm looking for actual photos of the car with the exhaust kit installed.
Hey Fireant...The post search doesn't pull up the ones I am asking for. Yes it does pull up CRX exhaust but only in the Best CRX vote pol no pics though, also it pulls up a sweet Greddy original SP long style NOT the SP2 I was asking about. Plenty of pics with the muffler and pipes but not the Apexi WS or Greddy SP2 on the car. Again I'm only looking / requesting pics of those 2 on the car, a back bumper shot or underneath the car shot. If you found pics why didn't you post a link to them.
"NOT related to anyone in particular "
This is a great forum but it has a lot of attitude , its a simple request. PLEASE DO NOT POST COMMENTS IF YOU CAN NOT HELP OUT WITH THIS REQUEST. ANSWERS like "SEARCH" are just lame , I'm sure others may need this pic also ; as the mfg does NOT have them on their web sites, and they SHOULD.
The request has been established in the FAQ, in Tysons post.
Maybe if people like yourself would put some effort forth instead of being spoon fed we wouldn't get so upset.
Do It Yourself and Misc.
*Ben Ogle's EF Resource Tech Page
*Wes Vann's EF Honda Page
How-to: Fuel Pump Cut Off Switch
*SiR Instrument Cluster Wiring
Cup Holder for CRX
The "easiest" brake upgrade you NEVER knew about
Brake Booster and Master Cylinder Interchangeability
Cracked Heater Control Fixed
No Start Diagnosis 101
Cooling System 101
ECU Codes and trouble shooting
ECU Codes and trouble shooting 2
Rebuilding your sunroof
DIY Painting Body Trim
Rust repair tips on how to weld 88-91 CRX rear quarter panels/rocker panels
Relocated Fusebox and Headlight Wiring (Wire Tuck)
More Wire Tuck
Even more Wire Tuck
Accord Climate Control Swap for CRX
OEM HID's into 9006 housing
How to Remove / Rebuild / Test CRX Alternators
How to Remove CRX / Civic Steering Wheel
How to Remove CRX Door Panel
How to Remove CRX Door Sill
*CIVIC/CRX EURO SiR CLUSTER Wiring
GSR cluster in 90-91 Crx w/ Pinouts, *w/ pics (but bad info?)
*HONDA DISTRIBUTOR REPAIR
*Honda Radio Wire Harness
How to convert your fuel lines and filter to Stainless -6AN hoses
Exhaust Pic Thread
Exhaust Thread
DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER *NEW*
Reskin Roof, Permanent sunroof removal
JDM CRX Sidemarker Write Up
Domelight fix
How to add intermittent wipers to your base 88-91 civic hatchback (STD, etc) *NEW*
Si to Hf Engine Harness
Seat Swap
Gauges in Climate Control or Radio Din slot
How to fix your idling woes! FITV IACV
See you would have had your answer a lot faster.
Cup Holder for CRX
Cooling System 101
More Wire Tuck
Even more Wire Tuck
Exhaust Pic Thread
Exhaust Thread
Domelight fix
Seat Swap
92civicfreak
Apr 1, 2006 10:00 AM
hondatuner20
10
Jan 25, 2006 11:56 AM
rex_racer728
23
Jan 20, 2006 07:30 PM
