rear mount/braket problem with B-series motor install
Old Feb 15, 2008 | 02:00 PM
blacK_Dc4's Avatar
Default rear mount/braket problem with B-series motor install
Sup guys .. new at EF's and have a quick question. Right now , the b18c1 is sitting in the EF engine bay with the driver side and passenger side mount on. The rear mount is bolted on to the rear subframe already. Now the problem is , the bracket that is suppose to bolt the mount onto the block does not match up . Here is a pic of it
I re-read the installation instructions from hasport and understand that we do need to have one side mount loose and the other not even on , and also to tighten up the back while lowering the engine into the car .. , but still , could it be THAT off right now as it sit tho ??! .. i ve looked at other EF with B-series and the rear bracket looks the same so it doesnt seem like we picked up the wrong bracket. The engine is also sitting the way its supposed to . heres a pic
Do u guys see anything wrong with the way it sits in the pics ? .. thanks
Old Feb 15, 2008 | 02:09 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: rear mount/braket problem with B-series motor install (blacK_Dc4)
move to mount to the other bolt holes
Old Feb 15, 2008 | 02:17 PM
89s1's Avatar
Default Re: rear mount/braket problem with B-series motor install (NHswaps13203)
yes, if you take that L-bracket out you'll notice another set of holes, use those ones instead, just to move the hasport mount over about 2.5 inches. to the right from where you're looking at it there.
edit: i can even see one of the exposed bolt holes you're supposed to use thru the bracket in the second pic.
Old Feb 15, 2008 | 04:50 PM
blacK_Dc4's Avatar
Default Re: rear mount/braket problem with B-series motor install (89s1)
.. mounts were already on the car so i didnt check if it was previously installed wrong .. thanks for all the help
Old Feb 15, 2008 | 05:12 PM
hammergunner
Mar 16, 2009 06:04 AM
pentsas
Mar 9, 2009 10:26 PM
95dc2teg
May 1, 2007 10:35 PM
IOSUA
34
Mar 5, 2007 12:02 PM
Bob_760
Sep 7, 2006 08:50 PM
