dc struts on a ek??????????
Old Feb 15, 2008 | 01:46 PM
uenolove's Avatar
Default dc struts on a ek??????????
My friend has some dc ohlins with apexi springs off a type r and i was wondering if i could use them on my 96-00 coupe???/?
Old Feb 15, 2008 | 02:36 PM
uenolove's Avatar
ok i found out that they do. but i need to know how to shim the rear shocks??? can someone help me?
Old Feb 15, 2008 | 02:38 PM
Ghetto Civic HX's Avatar
I love to drive
Default Re: (uenolove)
That just means you put some washers between the shock body and the lower control arm so that there isn't any play.
Old Feb 15, 2008 | 04:12 PM
blinx9900's Avatar
Default Re: dc struts on a ek?????????? (uenolove)
i hope the DC there comming off has forks in the rear and not the EYE hole, if it has the eye hole at the bottom of the shock it wont fit unless you buy the function7 LCA's.
Old Feb 15, 2008 | 04:18 PM
BlueIntegraBoy's Avatar
Default Re: dc struts on a ek?????????? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">i hope the DC there comming off has forks in the rear and not the EYE hole, if it has the eye hole at the bottom of the shock it wont fit unless you buy the function7 LCA's.</TD></TR></TABLE>
x2
RyanA
Suspension & Brakes
May 26, 2009 07:24 PM
MiNDTRiP03
Mar 2, 2008 12:16 PM
JDMASTER EJ8
Nov 26, 2007 02:19 PM
bigkshep
Aug 30, 2005 04:55 PM
Dropped90Integra
Jun 14, 2005 12:37 PM
