anyone know the weight of a type r front seat?
Old Jul 4, 2002 | 09:07 AM
gsr98vtec's Avatar
Default anyone know the weight of a type r front seat?
looking into getting some recaros or sparco seats. they weigh about 25lbs according to the website. what does the front seat of a usdm itr weigh approximately? roughly the same?
Old Jul 4, 2002 | 09:19 AM
Cosworth's Avatar
Default Re: anyone know the weight of a type r front seat? (gsr98vtec)
probably a few pounds less.
Remember, rails also add ~8-10lbs to that weight. So, you're looking at around 35-40lbs with your setup.
Old Jul 4, 2002 | 09:20 AM
AllMotorITR's Avatar
New User
Default Re: anyone know the weight of a type r front seat? (Cosworth)
I believe US ITR seats weigh in with rails at around 35-40 lbs.
Old Jul 4, 2002 | 09:21 AM
slowassR's Avatar
the whole interior weighs about 75 lbs i have been told. I would guess the front seats to weigh between 15-20lbs
Old Jul 4, 2002 | 09:31 AM
gsr98vtec's Avatar
Default Re: anyone know the weight of a type r front seat? (slowassR)
so you think that some recaros or sparcos with rails will weigh approximately the same as the stock fronts with rails?
Old Jul 4, 2002 | 09:32 AM
slowassR's Avatar
Im going with the evos, plan to order then next week
[Modified by slowassR, 1:32 PM 7/4/2002]
Old Jul 4, 2002 | 09:48 AM
Cosworth's Avatar
Yup, it'll be roughly the same weight (if you're thinking reclinable Recaro or Sparco seats). I woudlnt' even sweat the weight difference... unless you are going with bucket seats which should weigh good 10 lbs less than USDM ITR reclinable seats.
Old Jul 4, 2002 | 09:57 AM
norice's Avatar
The stock seats are 30lbs each without rails - probably 35 - 40 lbs with rails.
For reference, Recaro SRDs with Wedge brackets weight about the same.
Sparco Evos are under 15 lbs each; rails with sliders are 10 lbs or so.
Unless you are going with a non reclinable bucket seat, you will not save muchweight over the stock seats.
Old Jul 4, 2002 | 10:03 AM
mugenintegra16's Avatar
Default Re: anyone know the weight of a type r front seat? (norice)
when i mailed out my front two seats it weighed 43lbs each.
Old Jul 4, 2002 | 12:00 PM
Misfit's Avatar
Default Re: anyone know the weight of a type r front seat? (mugenintegra16)
2 front seats with rails are 76 lbs. that is with box. not too bad.
Old Jul 4, 2002 | 01:09 PM
gsr98vtec's Avatar
Default Re: anyone know the weight of a type r front seat? (MISFIT)
no worried about saving weight, just dont want to gain any weight if you know what i mean
jfcole
Oct 2, 2008 02:53 PM
Justin Olson
Honda S2000
Jul 7, 2006 10:46 AM
h-t sucks
Jun 2, 2005 02:22 PM
eymnewdc4
Mar 2, 2005 10:06 AM
ares650
Nov 25, 2002 08:57 PM
