buddyclub spec III
Old Feb 15, 2008 | 12:20 PM
skellator_thoj's Avatar
Default buddyclub spec III
I was wondering if the buddyclub spec III catback exhaust for 97-01 type-r will be a direct bolt-on to a 01 gsr without any modding??
Old Feb 15, 2008 | 01:19 PM
Default Re: buddyclub spec III (skellator_thoj)
up
Old Feb 15, 2008 | 01:44 PM
BlueR's Avatar
BC spec III catback is JDM length, meaning the bpipe is ~5 inches longer that usdm setups
you will have to get a JDM length cat that ~12 inches long
or
you can cut 5 inches off the bpipe if you want to used your 17inch usdm cat
Old Feb 15, 2008 | 04:06 PM
Bbasso's Avatar
Default Re: buddyclub spec III (BlueR)
but then he would loose the flange and if he cuts the other end he would loose the slip fit joint.
Basically he needs a proper ftting cat or test pipe or don't use.
Old Feb 15, 2008 | 08:32 PM
spock_rocker's Avatar
memoryFAB.com representative
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">BC spec III catback is JDM length, meaning the bpipe is ~5 inches longer that usdm setups
or
you can cut 5 inches off the bpipe if you want to used your 17inch usdm cat</TD></TR></TABLE>
on my spec II i bought a omni test pipe and removed the center section.. like a glove on OJ.. its tight
Old Feb 15, 2008 | 08:55 PM
CWTegRNo.160's Avatar
Default Re: buddyclub spec III (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">but then he would loose the flange and if he cuts the other end he would loose the slip fit joint.
Basically he needs a proper ftting cat or test pipe or don't use.</TD></TR></TABLE>
Well i thought i had a jdm length cat, but i don't so i ended up chopping off 3 to 4 inches because cutting a rewelding was free to me. I haven't had a problem since. The slip fit is still good as well. If it wasn't for Rob i don't think i would have gotten this exhaust.
Old Feb 16, 2008 | 02:53 AM
Bbasso's Avatar
Default Re: buddyclub spec III (CWTegRNo.160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWTegRNo.160 &raquo;</TD></TR><TR><TD CLASS="quote">
If it wasn't for Rob i don't think i would have gotten this exhaust.</TD></TR></TABLE>
ME? How did I influence your decision? Hopefully good
Old Feb 16, 2008 | 03:49 PM
ME? How did I influence your decision? Hopefully good </TD></TR></TABLE>
What Happened to those Bad *** pics you had. The flame is coming out of the exhaust was cool to me. That caught my attention, but I notice the angle the exhaust had the drew me in more. I ask you about the Vibration from the springs on the exhaust, and you helped me out by sending me a link to get these..........
bad
good
Old Feb 16, 2008 | 06:32 PM
Bbasso's Avatar
glad to hear my ricey fire shot helped you decide
Old Feb 17, 2008 | 05:42 AM
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">glad to hear my ricey fire shot helped you decide </TD></TR></TABLE>
LMAO
Old Feb 17, 2008 | 06:03 AM
Bbasso's Avatar
What Happened to those Bad *** pics you had. The flame is coming out of the exhaust was cool to me</TD></TR></TABLE>
Huh Huh...
rhys.l
Sep 6, 2012 02:32 PM
ITR3189
Aug 1, 2007 09:13 PM
HSPxNick
May 15, 2007 12:47 PM
EVIL_AWD
May 5, 2003 10:06 PM
Toda Party
Sep 13, 2001 07:48 AM
