88 CRX HELP! MPH GAUGE DOESN'T WORK.....
Old Feb 15, 2008 | 11:04 AM
i_VTEC's Avatar
Default 88 CRX HELP! MPH GAUGE DOESN'T WORK.....
I took out my dashboard yesterday to fix something. After installing it again my MPH gauge didn't work. I know it works because it worked before i took it off. All i want to know is if there is ANY WAY THAT I CAN CONNECT IT AGAIN WITHOUT REMOVING THE DASH?
Old Feb 15, 2008 | 11:12 AM
CRX Toad's Avatar
Default Re: 88 CRX HELP! MPH GAUGE DOESN'T WORK..... (i_VTEC)
Take the cluster cover off and look to see if it is connects on the back of the cluster. Also check out where it goes into the transmission. If you didn't disconnect it when you removed your dash I'd would said you either pulled it out or broke it.
Old Feb 15, 2008 | 11:14 AM
i_VTEC's Avatar
Default Re: 88 CRX HELP! MPH GAUGE DOESN'T WORK..... (CRX Toad)
I'm pretty sure i didn't break it. I just didn't connect it.... I forgot. Where exactly is it again? I know that sounds stupid but i don't remember.... (reason for not connecting it)
Old Feb 15, 2008 | 11:27 AM
i_VTEC's Avatar
I fixed it. Thanks TOAD!!!!
truborex
May 24, 2011 08:20 AM
BrownCRXSI
10
Feb 5, 2009 09:24 AM
mike_340hp_crx
Sep 4, 2004 09:08 PM
etp72
Jun 12, 2003 05:51 PM
_BURN_
Mar 23, 2003 11:44 AM
