Honda S2000 Honda S2000
Intallation Help? "Gauges"
Old Feb 15, 2008 | 10:53 AM
jdm j's Avatar
Default Intallation Help? "Gauges"
I have two mechanical gauges that I want to install (water temp, and oil press). To what do I connect the water temp sensor to? (what part of the block?) And how about for the oil press? Please post pictures to help specify. Thanks.....
Old Feb 17, 2008 | 12:25 PM
iam7head's Avatar
Default Re: Intallation Help? "Gauges" (jdm j)
no pictures(you lazy)
it really depends on what type of pick up/sensor you have with your gauges
1) oil pressure can be tee off from the oil pressure sensor port(not with brass tee), or via a sandwich filter adaptor. The first route will be cheaper but more work under the car.
2) coolant temp sensor usually are pair with a "water neck" which are meant to slick into the upper/hot coolant hose. ebay got a bunch of anodized knock off, just get one with the right fitting
tremblay
Nov 12, 2009 07:56 AM
wicked2night
23
Apr 29, 2007 11:32 AM
CRX Lee
60
Jul 22, 2005 09:13 PM
97AccordCD5
Dec 13, 2004 02:18 PM
VTECAcuraGSR
10
Jun 29, 2003 09:02 PM
