H22 head on F22 Motor????
Old Feb 15, 2008 | 07:18 AM
HONDASONLY530's Avatar
Default H22 head on F22 Motor????
I have an F22 motor in my 96 accord im curious if i can put an H22 head on it. and if i can what do i need to do it? and what is that going to do to my peformance?
Old Feb 15, 2008 | 07:32 AM
f22builder's Avatar
Default Re: H22 head on F22 Motor???? (HONDASONLY530)
Yes you can h22 head on f22 motor. It has been done many times. But ask yourself this:
What are your long term goals................*****wind blows******
I would start in the hybrid forum and read from there...also seach G23..by Pirate
That will give you an idea of what it will take...
If you do it I will buy your F22 head..
Old Feb 15, 2008 | 07:37 AM
Default Re: H22 head on F22 Motor???? (f22builder)
my long term goal is a turbo build i hear that the F22 is a good motor for a turbo build k can get an H22 head for super cheap so is that a good idea or a bad idea?
Old Feb 15, 2008 | 08:18 AM
f22builder's Avatar
If your long term goal is a turbo build I would hold off on the head swap.
If your car is going to be a DD I would at least rebuild the bottom end. New bearings, washers, rods, pistons. http://raceeng.com/p-7911-honda-f22855mm881.aspx is a good place to start. Dont bother with the head right now. Start saving money with at least a 25% overflow fund for mistakes and what ever else happens.
1. Buy a Manual for your car.
1.2 Don't buy from ebay unless it is something cosmetic
2. Have a second car.
3. Make a list of all the parts you are going to need with prices.
4. Figure out what items should be bought together so you dont have to keep taking the engine apart.
5. Once you have all your parts and everything is installed. GO TUNE YOUR CAR
This is all I can tell you because it has been said 1xxxxxxxxx times before on this site and others. I left a million things out but ya.... Good Luck
Old Feb 15, 2008 | 08:27 AM
Thnx!
Old Feb 15, 2008 | 10:06 AM
steerh67's Avatar
there is a how to guide for this exact procedure in the accord faq
JDMrickswag
Oct 18, 2017 09:06 PM
Morty
Jan 14, 2008 04:41 PM
HaOcNcDoArd96
Acura TL, RL & ZDX
Jun 24, 2005 07:06 PM
Don Johnson
Aug 27, 2004 07:04 AM
