My "reliable' DD just left me stranded.... got a question.
Old Feb 15, 2008 | 07:01 AM
89s1's Avatar
Default My "reliable' DD just left me stranded.... got a question.
Hey everyone, my 1991 dx as my reliable car i was using it to drive my wife to work, and after leaving a red light, it accelerated up thru first to 3,000 or 3,500 rpm no problem, then i pulled down into second, let the clutch out and it backfired a couple times, kept running for a second, then died. Now when i try to start it it just cranks over for a couple seconds and then pop fires but won't start.
I searched the issue, but really came up empty handed. "pop firing" and "backfire start" got me nowhere.
I am going to go change the plugs/wires because it seems like a spark issue to me. Not throwing any codes, and i hear the fuel pump prime up.
anyone have any other ideas?
Old Feb 15, 2008 | 07:02 AM
wiZCo's Avatar
Stouts 'n' Scotch
Take of your dist. cap and see if there's any damage (brown dust) or if the rotor button fell off.
Old Feb 15, 2008 | 07:05 AM
89s1's Avatar
Default Re: (wiZCo)
Nice, will do. I've gotta ride my bike 20 blocks down to where it died with a backpack full of tools and parts. I'll check that when i get there too.
I checked the dizzy visually, and i can report from memory that it didn't come loose and jump to full retard, so i'll check under the cap.
Old Feb 15, 2008 | 07:11 AM
IT GUY's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote"> the rotor button fell off.</TD></TR></TABLE>
that's my first guess.
Old Feb 15, 2008 | 08:00 AM
c0d0r's Avatar
yeah, check the dizzy. Same thing happened to my b16a. Cruising on the interstate and the car just died. I would try and crank it but all it would do was just pop and gurgle. The rotor screw came off and the button quit spinning. Good luck
Old Feb 15, 2008 | 09:21 AM
90efhatch's Avatar
Default Re: (IT GUY)
rotor button falling of is a common issue with those cars my si engine did that to me like 3 times it sucks but it makes you carry the tools to fix it on the side of the road.
Old Feb 15, 2008 | 10:19 AM
redefsir's Avatar
Default Re: (c0d0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0d0r &raquo;</TD></TR><TR><TD CLASS="quote">yeah, check the dizzy. Same thing happened to my b16a. Cruising on the interstate and the car just died. I would try and crank it but all it would do was just pop and gurgle. The rotor screw came off and the button quit spinning. Good luck</TD></TR></TABLE>
Same thing happened to me...
luckily it was as easy fix.
good luck
Old Feb 15, 2008 | 10:55 AM
Hondaisok's Avatar
Default Re: My "reliable' DD just left me stranded.... got a question. (89s1)
Or, it could be the igniter inside the distributor. That happened to mine once. I carry a whole spare assembled distributor (cap and everything) in my car that I can change out in about ten minutes if needed. Also carry a spare main relay.
Old Feb 15, 2008 | 11:08 AM
HondaHeddie's Avatar
Default Re: My "reliable' DD just left me stranded.... got a question. (Hondaisok)
I vote for loose rotor button
had the exact same thing happen to me
Old Feb 15, 2008 | 11:16 AM
98lude-t's Avatar
Default Re: My "reliable' DD just left me stranded.... got a question. (HondaHeddie)
i had the same happen to me but the diff was the belt jumped 2 or 3 teeth
Old Feb 15, 2008 | 01:06 PM
89s1's Avatar
Default Re: My "reliable' DD just left me stranded.... got a question. (98lude-t)
Well, this thread is a testiment that honda-tech still works. Ask a question in english, with as much info as you can give, and voila.... everyone nails it on the head.
It was indeed the rotor that had come loose.
Chalk up another win for H-T
all around
Old Feb 16, 2008 | 05:09 AM
nfereorhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">Well, this thread is a testiment that honda-tech still works. Ask a question in english, with as much info as you can give, and voila.... everyone nails it on the head.</TD></TR></TABLE>
Old Feb 16, 2008 | 07:02 AM
EKDee's Avatar
glad you found out the problem, now after reading how common this problem is I'm going to have to carry a few spare part and tools in my car. I drive 40 miles ONE WAY everyday to work and I'll be damned if I get stranded somewhere.
Old Feb 27, 2008 | 05:35 PM
c0d0r's Avatar
Yeah..plus tow bills really suck..especially when your school is twenty plus miles away....glad you got it fixed
Old Feb 27, 2008 | 05:42 PM
tnez's Avatar
Default Re: (90efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efhatch &raquo;</TD></TR><TR><TD CLASS="quote">rotor button falling of is a common issue with those cars my si engine did that to me like 3 times it sucks but it makes you carry the tools to fix it on the side of the road.</TD></TR></TABLE>
I used to always carry a little craftsman socket set in my rexy... cheap, fast and SAFE! you never know when you need a tool... glad you figured out the problem. My first experience with this was at CMI... missed out on warm ups looking for a new cap/rotor... got it to run when it counted though
Old Feb 27, 2008 | 08:52 PM
jr94513's Avatar
lol same thing happened to me twice once in my hatch another in my crx both of the times on the freeway!!! both times far away from home, tow trucks can get expensive
Old Feb 27, 2008 | 11:24 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Re: (jr94513)
i always keep tools in my 89 dx
mostly for my "smart" friends, but just in case.
it always ends up able to be fixed on spot, either by itself, or simple things
(all except the starter)
bart simpson
15
Apr 6, 2010 12:21 PM
tedo2007
13
Dec 4, 2009 09:58 AM
vtecn8ive
21
Nov 5, 2005 09:35 AM
ek_b16
Sep 7, 2005 10:35 AM
Honda Sport
Jun 4, 2003 05:27 PM
