D16Y7 and D16Y8 what are the differences...
Old Jul 4, 2002 | 07:19 AM
btlfedhatch's Avatar
Default D16Y7 and D16Y8 what are the differences...
I was told that there are parts that are swappable between the Y7 and the Y8. Like the injectors, the Distributor, and the Valve Cover. Is this true?
Old Jul 4, 2002 | 07:22 AM
DevinW's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (btlfedhatch)
I'm not sure, but I do know that you can swap the VTEC head off of the y8 and have a more powerful engine than a stock d16y8. Not sure about the procedure, but I'm sure if you search around you'll find it.
Good luck...
Old Jul 4, 2002 | 10:58 AM
FifthGearOnline's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (DevinW)
D16Y7 = 106hp non VTEC piece of junk....and i can say this because i have it
Old Jul 4, 2002 | 02:33 PM
Ricey McRicerton's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (fifthgearonline!!!)
grab the intake manifold off of the y8...talk to mista bone about the D series...he seems to know the most about them! Im plannin on doing a mini me swap shortly...try http://www.nerdsbyte.com/honda for info, and good luck!
Old Jul 4, 2002 | 02:39 PM
BARF1's Avatar
Old Jul 4, 2002 | 02:55 PM
RR98DX's Avatar
i hear that!
Old Jul 4, 2002 | 02:59 PM
Default Re: D16Y7 and D16Y8 what are the differences... (RR98DX)
I know that the Y7 is slow, and for some reason everyone keeps telling me that. But the question I asked had nothing to do with the horsepower of the Y7 or that the Y7 is non VTEC. I am asking if parts from the Y7 are the same on the Y7 and the Y8. Like the Distributor, the Injectors, the Valve Cover, stuff like that.
Old Jul 4, 2002 | 08:20 PM
mike97hb's Avatar
D16y7 are good motors after a little work and some D16y8 parts like Trans, intake manifold, clutch and flywheel header and CAI . It will keep up B16 with I/H/E or beat them. If you want more power out of the non-Vtec go TURBO. I just installed a A'pexi turbo and it is fast. I raced a JDM B18C in a 98 HB with slicks and keep up with no problem and I had 17" rims with street tiers. Turbo at 5 PSI that’s good I love my non-Vtec.
Old Jul 4, 2002 | 10:45 PM
liam821's Avatar
25 Year Member
The blocks are almost identical! The y8 has a knock sensor the y7 doesnt. They both have the same fuel injectors, all d and b series honda motors have 240cc injectors. The dist is most likely the same also, although the y8 of course has a real head while the y7 has a pos non-vtec head. The y7 has the lame intake manifold while the y8 has a real one. The valve covers are the same..you can swap those. Or you can use a valve cover off a 92-95 z6 that will work too.
Almost every part between the two is the same other then the head and intake manifold.
liam
Old Jul 4, 2002 | 10:59 PM
Quik89Si's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (mike97hb)
Wait a sec, so now what's your entire setup? This sounds interesting...the only other Turbo'd D16y7 I've heard of is RoaringTurtle's, in his hatch...I think he has the Greddy kit.
Fill me in!! Thanks
Old Jul 5, 2002 | 01:13 AM
mike97hb's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (Quik89Si)
ok here is what I have I know I am going to forget something. This is on a 97 CX Hatchback. The Apexi kit I have is a bigger turbo and the greddy is a bit smaller.
Soon to come is a Apexi AVC-R and a big intercooler.
D16y7
EX D16y8 intake manifold
EX transmission
10lbs flywheel
ACT 6 pad clutch and
Xtreme Pressure Plate
Fireball border exhaust
Venom fuel rail
255lph fuel pump
B&M fuel psi gage
NOLOGY Wires
Denso iridium spark plug
Vortec FMU 12:1
Missing Link MAP bypass valve
Apexi turbo kit for a 92-95 Ex/Si
Apexi turbo timer
Greddy BOV type s
EX gauge cluster with tack
Autometer phantom white air fuel
Autometer phantom white vacuum
[Modified by mike97hb, 10:14 AM 7/5/2002]
Old Jul 5, 2002 | 07:32 AM
cre18's Avatar
mini me
Old Jul 5, 2002 | 07:51 AM
Spade's Avatar
To actually answer your question.
Yes a lot of the parts are the same and yes 90% are swappable.
to compair part numbers go to http://www.hondaautomotiveparts.com
Old Jul 5, 2002 | 08:31 AM
Dr. EKology's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (Spade)
is it possible to do something like a ls/v as in taking the vtec head from the y8 and putting it on the non-vtec y7? my car is too slow
[Modified by EKology, 9:32 AM 7/5/2002]
Old Jul 5, 2002 | 08:42 AM
Quik89Si's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (EKology)
Yes, taking the head from a D16Z6/Y8 and putting it on ANY non-vtec SOHC 1.6L block is called a mini-me. Very possible, lots of people do it. Do a search for mini-me and you'll find lots of info.
Alex
Old Jul 5, 2002 | 09:39 AM
EVIL Hx Coupe's Avatar
you can swap most parts from the y8 to the y7 and also the y5.
Old Jul 5, 2002 | 10:16 AM
p0oty's Avatar
Default Re: D16Y7 and D16Y8 what are the differences... (Boost Pressure)
straightshot08
Oct 29, 2009 06:36 AM
crx-newbie
Jun 18, 2009 05:47 AM
d1nki
May 1, 2006 08:20 PM
honda_S
Jan 12, 2005 08:20 PM
