fuel filter
Old Feb 14, 2008 | 07:16 PM
hectic57's Avatar
Default fuel filter
sorry for this noob question, does anyone how to change a fuel filter on a 94 honda civic?
Old Feb 14, 2008 | 08:55 PM
ddd4114's Avatar
Default Re: fuel filter (hectic57)
Get a Hayne's/Helm's manual, which will have detailed instructions.
It is pretty obvious how to replace it, actually, just make sure you replace all the washers (which should be included with the new fuel filter) and that you don't torque the bolts down too much. I learned the hard way.
Old Feb 14, 2008 | 09:04 PM
Civic9390's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">Get a Hayne's/Helm's manual, which will have detailed instructions.
It is pretty obvious how to replace it, actually, just make sure you replace all the washers (which should be included with the new fuel filter) and that you don't torque the bolts down too much. I learned the hard way.</TD></TR></TABLE>
X2 on that be careful not to strip the fittings either i learned the hard way...
Old Feb 15, 2008 | 05:25 AM
jeproks's Avatar
Default Re: fuel filter (ddd4114)
What he said. Make sure you have lots of rags or paper towel to catch the gas when you remove the bolts.
Old Feb 15, 2008 | 05:36 AM
96hb's Avatar
Disconnect the battery, take off the gas cap to relieve the pressure, have some rags handy, and get to work loosening the fittings. It's a pretty easy process really.
Old Feb 15, 2008 | 05:57 AM
lee97ex's Avatar
Default Re: fuel filter (96hb)
after you take the gas cap off to relive the pressure let the car sit for a few
hours so that there is no pressure in the system when you take the old filter off
bobjohnson
11
Jun 5, 2008 06:26 PM
Agent Zero
Honda S2000
Mar 4, 2008 10:08 PM
handa
Apr 3, 2005 03:27 PM
Fez
Aug 27, 2002 07:48 AM
HPC
Aug 2, 2001 11:36 AM
