Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Just for your own good and for you wont spend money like i did for rev !!!!
Old Feb 14, 2008 | 06:13 PM
salviboi's Avatar
Default Just for your own good and for you wont spend money like i did for rev !!!!
a piston blew out and i need a new engine a new everything..... total cost for a new engine and all the work to be done was 4200 dollars man its not worth it......just race once in a while.....but dont over rev it.....it sucks not having your car for about 2 weeks and a half.....while driving a sentra which is super wack.....Take car of your car and dont make the same mistake i did
Old Feb 14, 2008 | 06:20 PM
Kidnkorner's Avatar
Default Re: Just for your own good and for you wont spend money like i did for rev !!!! (salviboi)
How did you over rev it and blow a piston out? Did you downshift instead of upshift? Do you have the Hondata reflash and rev past the factory intended MAX RPM?
You paid $4200, I hope you kept the old engine and/or parts, if not you just gave money away.
Old Feb 14, 2008 | 06:26 PM
salviboi's Avatar
Default Re: Just for your own good and for you wont spend money like i did for rev !!!! (Kidnkorner)
what i did was i went from second to third and i guess didnt make third all the way......the little red light came on and boooom i heard something i thought maybe it was just my oil filter but nope you should have seen the huge hole i had.....yea i stilll have the original k20z3 engine thats i messed up im using many of the parts i need....i brought a brand new engine from the dealer for 3500 0 miles not bad at all.....
Old Feb 14, 2008 | 07:41 PM
Quik89Si's Avatar
Sounds like you shoved in back into first and popped the clutch...the way you described it, you never would have blown your engine as the rev-limiter would have kept you save. Keep the new motor in better shape!
tengty
28
May 9, 2011 09:28 PM
GoLowDrew
Apr 2, 2011 01:12 PM
halfcard
May 4, 2007 07:02 PM
ddemers
May 15, 2006 04:40 PM
PhongT12
Nov 8, 2005 02:11 PM
