Help with 70mm BDL throttle body for K20Z1
[IMG]I have a question about a BDL throttle body. I bought the throttle body and started to remove all sensors from stock throttle body and put on BDL and I noticed a problem with the sensor on top that gets 2 screws to hold it down to the throttle body. Please if anyone can help me out I would really appreciate it. I'm really stuck and dont know what to do.
BDL Industries... make high quality throttle bodies, spacers, fuel rails, cam gears, etc... http://www.bdlind.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITeggy17 »</TD></TR><TR><TD CLASS="quote">The RSX does not gain much if anything from upgrading the throttle body.</TD></TR></TABLE>
How about upgrading the manifold in addition to adding a new throttle body ?
An RBC manifold is a great upgrade for the RSX. Otherwise, the throttle body really shows no gains on an N/A setup, maybe if you are running high power or boost.
If anything, just pick up an RBC manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITeggy17 »</TD></TR><TR><TD CLASS="quote">An RBC manifold is a great upgrade for the RSX. Otherwise, the throttle body really shows no gains on an N/A setup, maybe if you are running high power or boost.If anything, just pick up an RBC manifold.</TD></TR></TABLE>
how about puttin' on a JDM Honda Integra Type R Intake Manifold (PRC) compared to a RBC ??? yes
No
No
the RBC flows much better. again, TB will not net you gains without cams and more. also, the difference between the BDL and Spoon is that the Spoon starts out at 70mm and tapers down to 63mm or so. the BDL is just a straight 70mm through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">the RBC flows much better. again, TB will not net you gains without cams and more. also, the difference between the BDL and Spoon is that the Spoon starts out at 70mm and tapers down to 63mm or so. the BDL is just a straight 70mm through.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITeggy17 »</TD></TR><TR><TD CLASS="quote">RBC is the best manifold made by Honda out there. Period.</TD></TR></TABLE>
thankz for the knowledGe !
