question about crx dashes?
Old Feb 14, 2008 | 03:26 PM
CRX91SE's Avatar
Default question about crx dashes?
Alright i was wondering if the crx dashes from the 88-89 si are the same mounting to the 90-91 si body? Cause my 91si dash is haggered..
I know the cluster is more square in the 88-89, but will the 90-91 cluster fit on that one..
also is it a direct bolt in?
Thanks
Old Feb 14, 2008 | 04:25 PM
vtecrich's Avatar
Default Re: question about crx dashes? (CRX91SE)
Other than the cluster they are the same.
Old Feb 14, 2008 | 04:29 PM
CRX91SE's Avatar
Default Re: question about crx dashes? (vtecrich)
like will the 90-91 cluster mount to the 88-89 dash? with the more round cover?..
Old Feb 14, 2008 | 04:37 PM
290allen's Avatar
yes, you also have to swap over the cluster mounting brackets.
Old Feb 14, 2008 | 04:44 PM
CRX91SE's Avatar
Default Re: question about crx dashes? (290allen)
ok cool, thanks!
Old Feb 14, 2008 | 04:55 PM
crazykamper's Avatar
^^ for changeover all you really need to do is swap the cluster mounting brackets, and wiring if you really need it, dont forget to take off your vin from your old dash.... you may still need it!
Old Feb 14, 2008 | 06:18 PM
CRX91SE's Avatar
Default Re: (crazykamper)
ya i know ill do the vin aswell
Old Feb 14, 2008 | 08:54 PM
rawb16ED's Avatar
also the wiring for the tac is different it wont work right but its one plug short in the 88-89 the 90-91 have a xtra plug in the back
Old Feb 14, 2008 | 10:52 PM
CRX91SE's Avatar
Default Re: (rawb16ED)
I dont care about wiring, cause im still using my 91 harness..
Old Feb 15, 2008 | 12:18 AM
whiteknightef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawb16ED &raquo;</TD></TR><TR><TD CLASS="quote">also the wiring for the tac is different it wont work right but its one plug short in the 88-89 the 90-91 have a xtra plug in the back</TD></TR></TABLE>
Did this guy even read the OP
pnk_03
Jan 9, 2008 07:54 AM
julioboostamante
Dec 7, 2007 04:57 PM
4DRmafia
15
Mar 19, 2007 02:56 PM
kantfadedisazn
Jan 31, 2006 12:28 PM
iNetForce
25
Feb 20, 2004 08:59 PM
