Need help With my Da!
You splice all of them together.
Then you take that mess of wires and connect the to your JDM Fogs.
I think you do need to ground the black wire to your "fart can" otherwise you will lose hp
are you sure it has 2 red wires? only ones i have seen have a white,green,black,red
white=lights
red=power 12v constant or switched
black=ground
green or blue=coil neg side.(makes the needle go up and down)
hook up the green wire to the blue wire coming from the distributor. on the two wire plug..
white=lights
black=ground
GSRCRXsi
May 22, 2005 08:01 PM
Lei Siew Long
Jul 25, 2001 09:38 PM
