84.5MM BORE... is that safe with no sleeves
Old Feb 13, 2008 | 10:28 PM
johnnyjennings's Avatar
Default 84.5MM BORE... is that safe with no sleeves
i just bought a brand new freshly built bottom end.. and it is 84.5mm bore.. and i didnt have it sleeved.. its going to be street driven and races once in awile.. do you guys think it will be safe with me not sleeving it.. the hole build should push around 230hp.. hoping..
Old Feb 13, 2008 | 10:42 PM
A.E Motoring's Avatar
Default Re: 84.5MM BORE... is that safe with no sleeves (johnnyjennings)
so its a b20 bore to 84.5? or a 1.8
Old Feb 13, 2008 | 11:26 PM
Default Re: 84.5MM BORE... is that safe with no sleeves (Dual Cam Racing)
b20 bore to 84.5
Old Feb 14, 2008 | 04:24 AM
integraman 95's Avatar
u shouldnt have a problem as long as you get it tuned properly, im starting my build next week
84.5 rs machine pistons 11.7.1 comp.
ported b16 head
revsprings and retainers
blox b cams
bdl gears
type r manifold
my buddy has a built b20 vtec for bout 2years and still runs strong as hell 237hp and 167tq.
good luck with ur build.
Old Feb 14, 2008 | 02:53 PM
pgpbubble's Avatar
Whats safer, a 81mm block bored to 84.5 or a b20 block bored to 84.5?
Old Feb 14, 2008 | 03:06 PM
h22crxpwr's Avatar
Default Re: 84.5MM BORE... is that safe with no sleeves (pgpbubble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble &raquo;</TD></TR><TR><TD CLASS="quote">Whats safer, a 81mm block bored to 84.5 or a b20 block bored to 84.5?</TD></TR></TABLE>
holy crap are you kidding me... an LS block with stock sleeves bored to 84.5!!!! damn i don't even think thats possible. you will have a peice of paper for a sleeve!!
the B20 block is already 84 bore. i've gone 84.5 with no problems on a few all motor builds.
impossible on the 81 bore.. very possible on the B20 block.
Old Feb 14, 2008 | 03:10 PM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble &raquo;</TD></TR><TR><TD CLASS="quote">Whats safer, a 81mm block bored to 84.5 or a b20 block bored to 84.5?</TD></TR></TABLE> you can not bore a unsleeved 81mm block to 84.5mm you can bore a b20 to 84.5mm but i only sagest for all motor. if nos or turbo i don't sagest using a b20 unless your sleeving it and yes i know guys do it but most of the time they crack the sleeve and ruin there new pistons.
Old Feb 14, 2008 | 03:29 PM
Power Rev Racing's Avatar
Default Re: 84.5MM BORE... is that safe with no sleeves (Golden Eagle)
I built a B20 for a customer about a year ago. 84.5mm. 11.5 compression, naturally aspirated. Ran good. But then he decided to spray it, and cracked the sleeve the first time he sprayed the motor. I am not sure how much nitrous he sprayed, but he cracked sleeve, and messed up the brand new weisco pistons that were in the motor.
Old Feb 14, 2008 | 03:59 PM
h22crxpwr's Avatar
Default Re: 84.5MM BORE... is that safe with no sleeves (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">I built a B20 for a customer about a year ago. 84.5mm. 11.5 compression, naturally aspirated. Ran good. But then he decided to spray it, and cracked the sleeve the first time he sprayed the motor. I am not sure how much nitrous he sprayed, but he cracked sleeve, and messed up the brand new weisco pistons that were in the motor.</TD></TR></TABLE>
yep seen that happen many times... nitrous motor b20 i just usually spray with the stock block. or on the RS pistons with stock 84 bore. seems to hold up okay.. squeezing over a 100 shot on it. those sleeves are VERY unforgiving however.. tuning has to be very good.
Old Feb 14, 2008 | 04:08 PM
Teamdiesel's Avatar
how much displacement exactly is a B18C1 sleeved with 85mm bore and a 87.2mm crank?
Old Feb 14, 2008 | 08:43 PM
d15Beta's Avatar
3.1416 x bore x bore x stroke / 1000
Old Feb 15, 2008 | 09:27 AM
manoy's Avatar
Default Re: (d15Beta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15Beta &raquo;</TD></TR><TR><TD CLASS="quote">3.1416 x bore x bore x stroke / 1000</TD></TR></TABLE>
Old Feb 15, 2008 | 09:30 AM
manoy's Avatar
don't even think of it ...
Old Feb 15, 2008 | 03:20 PM
pasaunde's Avatar
85mm with a mild build seems to be holding up fine for me, I've got about 600 hard track miles and counting..........
Angel4768
Nov 21, 2011 08:21 PM
RippSpeed
14
Feb 19, 2008 03:39 PM
PowerSpeed Motorsports
17
Mar 16, 2006 11:04 PM
hoskos
Dec 12, 2005 08:08 PM
TypeR0149
Aug 22, 2001 12:32 AM
