which oil pickup?
Old Feb 13, 2008 | 10:13 PM
lurkin' eg's Avatar
Default which oil pickup?
yo whats up yall. i have a question. i have a lsvtec setup. i had to take off the oil pan and replaced it with an ls one. i found out originally i had a gsr oil pan and windage tray. my question is do i also have a gsr oil pickup or will the ls one fit with the gsr windage tray. And also are the two different sizes? and also is it okay to run a gsr oil pickup with an ls oil pan?
Old Feb 17, 2008 | 09:34 AM
saleensolution's Avatar
Default Re: which oil pickup? (lurkin' eg)
the gsr pick up is way different from a ls. the gsr has a main cap girdle on it and thus the windage tray and pick up is different. the ls does not have a girdle (unless someone put one on it) and it just has regular main caps and the pick up for it is different.
so in a nut shell if you have a girdle on it get a gsr, if no girdle get a ls
Old Feb 18, 2008 | 07:15 PM
lurkin' eg's Avatar
Default Re: which oil pickup? (saleensolution)
thanks man. I actually found out that i have a girdle on it (i didn't get too see under the windage tray so i didn't think of it much). so i know i have the gsr pickup. but thanks for the info anyway.
93egSLEEPER
Sep 27, 2009 07:05 PM
esoterEK..
Feb 22, 2007 09:36 PM
xxmikexx206
Jan 8, 2007 09:08 AM
Turbotype
Feb 21, 2005 11:15 AM
SLOW EF8
Jul 17, 2003 04:14 AM
