Edelbrock #4760 Manifold vs Skunk 2 Manifold
Ok so I’m wanting every ones thought on this. I have used the Edelbrock Manifold and liked it. All my friends say they like the Skunk 2 manifold. What is the power difference between the two and the difference between short and long runners?The motor build that these manifolds will be on is a Fully built LSV with gsr crank and rod, 12-1 Cp Pistons and gsr head with ctr cam shafts and flat valves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gs1gsr »</TD></TR><TR><TD CLASS="quote">12-1 Cp Pistons and gsr head with ctr cam shafts and flat valves.</TD></TR></TABLE> I think you need better cams first...
from the edelbrocks website: "HONDA/ACURA B-SERIES MANIFOLDS Optimized for maximum power from 7,000 to 10,000 RPM"
they arent kidding when they say that, midrange (anything below 7k) really takes a dump on those manifolds.
type R "style" manifolds arent "supposed" to work that good on GSR heads cause they are designed for the port angles of a typeR. the PN of the edelbrock was for a GSR so im guessing you have one.
personally id go with a performer X instead of a victor X if this is a street motor.
HondaIntegraR
185
Mar 12, 2010 09:13 AM
i_drive_a_honda
Aug 7, 2008 02:45 PM
powercenter7
Dec 10, 2004 07:45 PM
